delsol speedo question
hello, i have a 1.5ltr vtec honda delsol and the speedo is not working properly,while the rpm works fine.i have changed the vss sensor but the problem remained.
my second option is to change the instrument panel.,now the problem is this: i have found 1 which came off a 1.6ltr vtec honda delsol,and as mine is 1.5ltr would it work with my car?
thanks a lot
thanks a lot
Re: delsol speedo question
the km/h are just an example.
Well I am not sure what is your top speed, but what I am trying to say is everything will stay the same
i.e. If your redline was 6800rpm, your car's redline will still be the same(6800rpm) even tho the new cluster may redline at 8000rpm or so. same thing with the speedo
so mine used to go to 8000rpm, and the new one goes to 9000rpm. if i install it the needle wont go till 9000 but will stay to 8000,am i right?
jxhxb
12-29-2007 08:58 PM
