Check engine light and Brake Question
http://www.youtube.com/watch?v=g-gT8...layer_embedded
*I am not sure if iam reading this correct. Is they Code #5??? and how can i fix this code it is throwing????
*when stopping my brake pedal sometimes goes soft/falls to the floor.
what things can i check so i can slove this problem???
Iam alittle in the dark on were to start. So any help/tips would be helpful.
i actually think its throwing code 14.
http://check-engine-light-codes.blog...retrieval.html
and as far as your brakes, when was the last time the pads/rotors/fluids were changed? my best guess is that one or all of these are starting to go bad on you.
for the code im not sure if im tripping but im readin 41, and for the brakes start with bleeding them if you havent recently. i used to have the same brakes problem as you and it turned out to be a leaky master cylinder. check the 2 bolts holding the master to the brake booster and make sure they are tight and check for fluid leaking.
Thanks guys.
They brake pads are good.
If i didn't see any air bubbles in the brake two brakes should i continue to bleed the front two as well????
I will check on those two screws on the m/c and see if there tight.
Iam might just replace m/c and go from there. dunno
94CivicLife
Feb 27, 2016 10:00 AM
