Drag WRX from a local NW shop
Old Sep 1, 2009 | 07:27 PM
Ubar Jay's Avatar
Default Drag WRX from a local NW shop
Just thought I'd share this with you guys cause I know a few of you are into subies.
as the math works out with 450 rwhp and the full race weight with me in it at 2500 lbs we should be running low 10's no problem. we are not going for any crazy power right now because we want to just be able to go out weekend after weekend and run low 10's everytime. maybe at the end of next year we will push it up further but for now reliable is our goal and 450 wheel is very reliable in these engines.
as an update on whats done:
cp forged pistons
wrx heads
arp studs
fp red turbo
gt spec header up-pipe combo rotated by me
45mm turbosmart external wastegate
turbo 400 3 speed trans with straight cut gears and transbrake
6500 stall hughes torque converter ford 9" rear end narrowed with strange axles, strange spool, strange carrier and 4:56 gears
32x16 good year slicks with 14x15 weld pro star drag wheels
aeromotive a1000 fuel pump
redone by me custom fuel rail setup
I am sure there is more I am leaving out but just wanted to get an update in here real quick
thanks-
bobby
check out their site
http://www.preracing.com/home.html
Old Sep 1, 2009 | 08:06 PM
robbieshonda's Avatar
Default Re: Drag WRX from a local NW shop
saw this on nasioc his car has always been pretty cool.
Old Sep 1, 2009 | 08:16 PM
JDM KID 510's Avatar
Nice!
Old Sep 1, 2009 | 08:58 PM
chunty kevin's Avatar
damn that is not a wrx anymore
Old Sep 2, 2009 | 04:25 AM
StreetEG's Avatar
all that work with 450 wheel? thats hard for me to understand for a full season.... but who puts an FP red on a car like that?
Old Sep 2, 2009 | 11:20 AM
Arsenal's Avatar
The wheels and tires seem a bit much for that much power.
Old Sep 2, 2009 | 03:38 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Interesting.
Old Sep 3, 2009 | 12:46 AM
Spec R's Avatar
i've seen all the NA diehards do it with less power
Old Sep 3, 2009 | 01:05 AM
Ubar Jay's Avatar
The car could be pushed way more. Reliability and consistency is all he's looking for right now.
the tire that we went with is a little larger than we expected to go but when we got the wheels I was able to get the tires for an extra 100.00 with only a couple passes on them so I said to myself that is a really good deal and its cheaper to buy these tires and make them fit then it is to buy new smaller tires then have to get them mounted and balanced. not only that I do plan on pushing some serious power eventually and I don't want to have to redo anything. I just want to be able to crank up the power and go run it. so yes it is overkill but overkill is a good thing. I have been saying to people that if I cant get a sponsor to throw a motor at this after next race season then I will probably put something really stupid together and go for the world record. right now as far as I know its the Rigoli brothers with a similar setup in a gc chassis that has the "worlds fastest subaru". so for now we just want to run low 10's over and over and over again. then after everyone is pretty much sick of seeing it do 10's then pump it up and see what we can do with it.
thanks-
bobby
Old Sep 4, 2009 | 05:42 PM
hai_tech's Avatar
badass wrx
Old Sep 5, 2009 | 08:05 AM
SouLaQuaRiuS's Avatar
Wow... wheel tubs on a WRX!!!
Old Sep 7, 2009 | 02:30 PM
Smokinsax's Avatar
The Boot
so sick...that thing must be a blast to drive!
Old Sep 9, 2009 | 11:05 PM
druidesque's Avatar
i think he's at the right hp level with a boxer motor...haha.
Old Sep 10, 2009 | 09:03 PM
toshiro's Avatar
I bent my Wookiee
When I saw the tubs I did this:
Damn!
HatchSi
Apr 29, 2007 10:08 PM
NOPIDRAGS
Dec 10, 2005 08:09 AM
JDMvtecDRAGSTA
10
Feb 13, 2002 09:07 AM
Trajic
Jan 22, 2002 01:15 PM
LudeSi-93
Jun 19, 2001 12:21 PM
