Sluggish DA
Old Sep 1, 2009 | 06:09 PM
Fall_out_boy_99's Avatar
Default Sluggish DA
This last weekend I did a motor swap in my 91 Integra LS. The motor I put in it is out of a 94 Integra LS (B18B1). The motor runs fine and idles fine, but when I am driving under 3k rpm it kinda stutters a little or is sluggish. When I bought the car, it had an ECU for a B16 in it and that is the one that I am currently using still. Could that be the problem or should I look at the plugs and wires? As soon as I get over 3k rpm it doesnt stutter and runs fine.
Old Sep 1, 2009 | 10:19 PM
Circusraven's Avatar
Default Re: Sluggish DA
Check your timing. Could be your problem.
Old Sep 2, 2009 | 04:47 AM
ok, what effect would the B16 ECU have on a stock B18B1? I am currently looking for a stock ECU right now. I know that I have a check engine light for the VTEC not working.
Old Sep 2, 2009 | 06:09 AM
deftonerider's Avatar
put the distributor and ecu from your da in and make sure your running a resistor box on the da injectors
Old Sep 2, 2009 | 10:44 AM
stocker2shocker91's Avatar
I requested a short story for a title.
sounds like it could be a distributor cap
Old Sep 2, 2009 | 08:11 PM
ok tonight I bought a new distributor cap and some plugs, I put the cap on and it made a little difference. It almost seems like its backfiring a little. I can hear it every once in awhile.
Old Sep 3, 2009 | 09:24 PM
alright, im still having the problem bad. I pulled out the ECU and the number on it is 37820-PWO-000. Do you think this is the reason I am having so many problems? My current setup is 91 Integra LS, with a B18B1, and stock LS manual tranny that came with the car.
Old Sep 4, 2009 | 02:38 PM
anyone?
norevo
Feb 18, 2007 10:19 AM
asubennett
Aug 27, 2005 10:15 PM
simplypinoyy
Oct 14, 2004 07:09 AM
Purple94Integra
Jun 25, 2004 07:27 AM
JohnX6
Jun 16, 2002 10:08 PM
