95 dc pass window not working???
Old Sep 1, 2009 | 09:51 AM
dc4teg95's Avatar
Default 95 dc pass window not working???
OK so my pass side window just stopped working. Works fine with the driver switch so i tried replacing the pass side switch. No luck so changed driver side as well still no luck. double checked to make sure window lock was off and it was. checked all fuses. nothing. Can any one help me figure this out?
Old Sep 1, 2009 | 11:06 AM
DKYamada's Avatar
Default Re: 95 dc pass window not working???
did you check the wiring to the switch on the passenger side?
Old Sep 1, 2009 | 12:24 PM
dc4teg95's Avatar
i have wiggled and checked all the wires leading to the door and visually i see nothing wrong
Old Sep 1, 2009 | 04:51 PM
Oreo-TeCk's Avatar
open ur panel and check all the plugs ... i've seen integras that has had this same problem and its because of connectors coming loose...connector to the switch...the door harness,the harness that goes from the drivers side to the passenger door... doesnt hurt to follow the wires look for anything tampered
Joey Mitchell
Oct 18, 2018 04:59 AM
Chrisxnj
10
Dec 6, 2016 01:21 PM
dc4teg95
Sep 1, 2009 12:26 PM
funkylemons
Audio / Security / Video
Nov 27, 2002 10:50 AM
Erik95LS
Dec 19, 2001 06:39 PM
