car randomly dies
Old Aug 31, 2009 | 09:42 PM
smd4life's Avatar
Default car randomly dies
i have a 93 hatch with a b18b1 in it, sometimes my car will randomly die at idle, and not start back, i can turn the key over and back and prime the pump 2-3 times and it will run at idle for 10 secs+-...i have to get some starting fluid and spray the air filter for it to start
Old Aug 31, 2009 | 09:48 PM
fryman's Avatar
Default Re: car randomly dies
maybe its flooding...try starting it and then when it dies and wont start,open the throttle all the way and try to start it or take off the air filter and try to start it....
or maybe your spark isnt strong enough and your distributors going bad?
i dont know but those are the first things i would check.
Old Aug 31, 2009 | 09:53 PM
98civdx's Avatar
Master Detailer
check the injectors maybe its not getting enough fuel, also check plugs,wires,cap.
any cels?
Old Aug 31, 2009 | 09:54 PM
smd4life's Avatar
ive already replaced the fuel pump with a gsr pump...could it be a relay?? im lost any help is greatly appreciated
Old Aug 31, 2009 | 09:57 PM
98civdx's Avatar
Master Detailer
if the pump is priming i doubt, but check it as well.
pull the plugs, and look at them to see if its runing lean.
my guess its not getting fuel or spark, when you spray starter fulid in it how long does run?
any cels?
Old Aug 31, 2009 | 10:04 PM
SWISS_MISS's Avatar
i would say it sounds like a main relay. its up under the dash and they are notorious for going bad and being an itermitent problem.
do a h-t search for main relay
Old Aug 31, 2009 | 10:10 PM
Former User's Avatar
I agree. If it starts with starting fluid, I would guess the main relay may be bad.
Old Aug 31, 2009 | 10:11 PM
98civdx's Avatar
Master Detailer
damn, i never even thought of the main realy, but i agree.
Old Aug 31, 2009 | 10:13 PM
SWISS_MISS's Avatar
this is going to sound crazy but next time it wont start use your left foot to give the underside of the dash a kick. it should run after you do this.
Old Aug 31, 2009 | 10:19 PM
eg grom's Avatar
Definently the main fuel relay, I had that exact same problem a couple years back and was starting my car with carb cleaner for a month before I found out what it was.
Old Sep 1, 2009 | 03:52 AM
smd4life's Avatar
i figured it to be some sort of relay...thanks a bunch guys ...big help
Old Sep 1, 2009 | 05:36 AM
Crossbreeder's Avatar
what does your car idle at? I would adjust your idling screw, by unpluggin your IAC plug and set the idle at around 600rpm, then shut the car off, plug the IAC plug back in, reset the computer. Then check your main relay, i dont this we have a fuel problem here.
JAGCB7
Jun 24, 2015 02:37 AM
Dave_Dc2
12
Feb 25, 2009 11:37 AM
ludecrasy87
Dec 10, 2006 09:07 PM
dan4h22a
Nov 6, 2004 08:53 AM
lazykiwi
May 13, 2004 11:55 PM
