engine blown from turbo
Old Aug 26, 2002 | 06:32 PM
wildesh's Avatar
Default engine blown from turbo
Hi I have a 97 prelude sh and I put a Drag gen 3 turbo kit on it, it hit boost then cut out . It did that four times and melted the number 4 piston and scored the cylender wall and fried the rings. any thoughts on what might have hapened? thanks
Old Aug 26, 2002 | 06:36 PM
Beast53568's Avatar
Default Re: engine blown from turbo (wildesh)
What did you have for Fuel Management. If you say the FMU there is yur problem. Also how much boost were you running and who did the install?
Old Aug 26, 2002 | 06:44 PM
PrecisionH23a's Avatar
you had a lack of fuel therefore detonated, that will melt your piston everytime. that or your ignition was too far advanced and while you were boosting it wasnt retarded enough.
Old Aug 26, 2002 | 07:09 PM
satan_srv's Avatar
Default Re: engine blown from turbo (GudeH23a)
...wasnt retarded enough.
Heh heh oh I think he was retarded enough
Just kidding sucks to hear man...this certainly does empasize the need for tuning especially if you're boosting. As the others asked, I'm interested to hear what Fuel management you had..
Old Aug 27, 2002 | 07:05 AM
wildesh's Avatar
The person who did the install is a honda tech and he didn't install the high flow fuel pump included in the kit,
Old Aug 27, 2002 | 07:14 AM
apexii's Avatar
Well that would be your answer. This is a perfect chance to get it sleeved. Give vince@goldeneagle a call to find what works best for your plans.
to the "honda tech"
aklucsarits's Avatar
New User
A fuel pump alone would likely not have prevented failure. You needed some method of fuel tuning - like standalone or piggyback ECU or, at a minimum, a fuel pressure riser. It's all about the tuning. There is a fragile balance you must maintain when adding forced induction on a car that was not designed for it.
Any idea how much boost you were trying to run?
Good luck,
Andrew
Old Aug 27, 2002 | 07:22 AM
H23 Power's Avatar
Default Re: engine blown from turbo (aklucsarits)
the kit comes with a FMU, so when it tried to raise pressure, the fuel pump failed...makes sense
Old Aug 27, 2002 | 11:44 AM
killerprelude86's Avatar
wow sorry man i hope you get it fixed soon i know it sux being with out the lude
speedfrk69
Apr 13, 2004 03:50 PM
jazz215
Aug 20, 2003 01:43 PM
Fired Honda
May 23, 2003 05:24 AM
Fired Honda
May 23, 2003 12:05 AM
turbogsr13z
Mar 16, 2002 12:16 PM
