Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
OMNI POWER OMNIPOWER Front Lower Control Arms -- Civic -- Integra -- FLCA
Old Aug 31, 2009 | 12:53 PM
Innes's Avatar
Default OMNI POWER OMNIPOWER Front Lower Control Arms -- Civic -- Integra -- FLCA
Contact
Email -- James@IPGParts.com
Phone -- 407-324-4684
PM
We have 6 Pairs of these available -- that is it !!!!
$295 shipped in the continental 48 states
Brand New Omni Power USA Front Lower Controls arms for any 1992-1995 Honda Civic, 1994-2001 Acura Integra.
Save Weight !!!!
Unique only to the Omni-Power product line, our light weight front lower control arms (FLCA's) are forged with certified T6-2014 aluminum (100% stronger than 6061-T6). Pure polyurethane bushings are used that wont squeak or crack like other poly bushings that use fillers to cut costs. Each control arm is then hard anodized to eliminate corrosion and maintain a show quality look. Omni-Power uses a solid design for added strength and is the only company to offer an aluminum FLCA for EG and DC model vehicles. These FLCA's are a direct replacement for the front 2 piece design and require no modifications for an easy install. Typical weight savings is approximately 8 pounds depending on the vehicle model. Each nut or bolt attaching the FLCA to the vehicle including the ball joint torques to 38 ft/lbs + or - 2 ft/lbs. If ball joint removal is required to change an axle or other part, use of a pickle fork is needed. Never use a hammer to release the ball joint from the FLCA, as this will damage the FLCA and may cause it to fail. Tested and developed on 1000 HP drag race cars as well as road and auto-x vehicles. This part is suitable for street and track use and is equal in strength to the OEM counter part when installed correctly. You won’t find a higher quality front aluminum control arm anywhere.
Contact
PM
Old Sep 1, 2009 | 07:01 AM
Innes's Avatar
Default Re: OMNI POWER OMNIPOWER Front Lower Control Arms -- Civic -- Integra -- FLCA
ttt
Old Sep 2, 2009 | 03:43 PM
Innes's Avatar
http://ipgcoating.com/2009/09/01/pow...-mirror-black/
Old Sep 11, 2009 | 08:32 AM
Innes's Avatar
http://ipgcoating.com/2009/09/07/hig...d-black-satin/
Old Sep 11, 2009 | 10:58 PM
Code Blue's Avatar
do these allow you to run the swaybar as well? I guess I'm not picturing it correctly in my head when it says replaces the 2 piece oem arm completely
Old Sep 12, 2009 | 05:44 AM
Innes's Avatar
yes you can still run your sway bar with these
these just replace the front portion of your oem 2 piece front lower control arm
Old Sep 14, 2009 | 03:29 PM
Innes's Avatar
http://ipgcoating.com/2009/09/11/coa...rts-and-domes/
Old Sep 16, 2009 | 01:23 PM
Innes's Avatar
http://www.ipgparts.com/index.php?ac...ge=0#article19
Old Sep 18, 2009 | 06:55 AM
Innes's Avatar
ttt
Old Sep 20, 2009 | 03:31 PM
Innes's Avatar
http://www.ipgparts.com/acura-integr...y-rlz-665.html
Old Sep 23, 2009 | 07:12 AM
Innes's Avatar
www.ipg-supertech.com
Old Sep 27, 2009 | 05:52 AM
Innes's Avatar
http://www.ipgparts.com/acura-integr...heels-217.html
Old Oct 1, 2009 | 07:38 PM
Innes's Avatar
http://ipgcoating.com/2009/10/01/ipg...ro-turbo-kits/
Old Oct 1, 2009 | 07:39 PM
S2Integra's Avatar
Noiice
Old Oct 4, 2009 | 05:37 AM
Innes's Avatar
ttt
Old Nov 15, 2009 | 01:59 AM
damndan23's Avatar
im lovin these....ima havto get a set of these soon
Old Nov 16, 2009 | 12:05 AM
DisturbedK24's Avatar
i take it these are out of stock now? pm me if they are in stock becaus im placing an order right now
Old Nov 16, 2009 | 08:50 AM
Innes's Avatar
i have some more sets left, we uncovered some old stock -- we have them ready to ship !!!
Old Nov 18, 2009 | 11:55 AM
Innes's Avatar
http://www.ipgparts.com/used-parts-6...train-667.html
Old Nov 20, 2009 | 12:16 PM
Innes's Avatar
Old Nov 22, 2009 | 04:15 PM
Innes's Avatar
ttt
Old Nov 23, 2009 | 06:11 AM
EFvtec Yo!'s Avatar
Hey man do you guys stock omni power coilovers? lookin for a set for a 97 Civic.
Old Nov 23, 2009 | 07:32 AM
Innes's Avatar
as far as i know omni isn't offering coilovers anymore
we can offer Blox Racing or Function and Form ones though if you are interested in either of those
Old Nov 25, 2009 | 08:39 AM
Innes's Avatar
often immitated, never duplicated
Old Nov 29, 2009 | 02:12 PM
civicMasterpiece's Avatar
Got a 2000 EK JDM RHD CTR will these fit on my car?
Got any left?
