Swap from D16 to D15
It will be my first time doing a swap.
The car is a 93 Delsol, I'm taking out the D16 and putting in a D15... I know... don't ask, oil starvation ftl
So anyway, can anyone direct me to a thread, or maybe a website that covers the swap from the first to last nut? From lurking around I found it should be plug and play and all... but I don't want to miss a step, overlook something and mess it all up. I've done my share of mechanical work but I've never been down the swap path.
what D15? It should be completely plug and play. What motor did you ahve before and what one are you putting on there now? because if you didnt blow your old head you can swap it on the new motor.
The Sol currently has a D16Z6, the "new" motor going in is a D15xx(coming out of a 94Hatch DX I beleive)
I thaught about doing the mini-me swap thing, but I read it's more trouble than it's actually worth so I dropped the idea. I just want to ride my Sol hassle free
This is not a picture of my motor, but the bottom end looks exacly like that. The hole in the block is located at the same place, and it's about the same size. So my D16 currently looks like that
im in the same situation as you i have a ek hatch tho so mine isnt plug and play i have a d15b with a vx head. My d167y threw a piston bought this motor didnt look at it closely and it was a d15b so o well i only need a distributor now out of a 92-95 vtec civic . Cant find anyone selling one.
I thaught I read somewhere I had to get a different timing belt and yada yada yada...
The headgasket on the D15 is brand spankin new, so is the timing belt and water pump. I think for now I'll concentrate on getting the D15 out of the Hatch and into the Sol, and maybe look further into the mini-me once I get borded of the D15. Winter is coming soon anyway lol...
So yeah, I really need to do where to start and where to end with the swap.
The Delsol is standard, the hatch is auto...
Would I be able to pull everything from the top? Engine with trans attached? Or will I have to jack the car high enough to slide it from under? I'm thinking it will be easier to attach the trans to the engine while the engine is out of the car...
So basicaly...
drain coolant, motor oil, trans oil
disconnect all harness, throttle cable, vaccum lines, coolant lines
remove axles
attach engine to crane
remove engine mounts
remove engine
all that in reverse to put back in
Is that it?
To attach engine to crane, I screw a bolt into the dizzy mount, screw a bolt where the timing belt cover attaches, attach a chain to both bolts and link the chains to the crane?
So basicaly...
remove axles
remove engine
Is that it?
yes basically. All you need is a strong point or stong bolt to attach the chains to. And yes its alot easier to put the tranny on the motor when its outside of the car.
bruvaman
Jul 16, 2002 02:05 PM
