Leaking rear window 91 Hatch
Old Aug 31, 2009 | 09:41 AM
InTheLBC20's Avatar
Default Leaking rear window 91 Hatch
Anyone know any cheap alternative to fix leaky rear windows on a hatch? I dont have any money right now and it rains everyday around here.
Old Aug 31, 2009 | 09:43 AM
mitsubishiv5's Avatar
Default Re: Leaking rear window 91 Hatch
caulk.
Old Aug 31, 2009 | 10:58 AM
DVS_SI's Avatar
if it sags down you could just readjust it. The seal could have failed also. Post a pic of where it is leaking. Caulk would fix it but would make a big ugly mess.
Old Sep 1, 2009 | 09:54 AM
InTheLBC20's Avatar
yeah i def DONT want to caulk...i talked to my buddy at the auto parts store hes gonna hook me up on some generic wheather stripping.
Old Sep 1, 2009 | 10:26 PM
77amc's Avatar
The cheapest fix I've found is just pull the weatherstripping ALMOST off and just lightly put it back on the seam. Shut the hatch to let "it" push it down. And spray some silicone around the seal too.
If it's the window itself, you may have to search a glass company.
My 86 si hatch would leak up by the hindges along the seams. The P/O had installed hard bushings and any jaring would go to the weakest part. (clear rubber cement fixed it)
E
E
Old Sep 2, 2009 | 08:30 AM
noone got my joke.
Old Sep 2, 2009 | 11:36 AM
grog's Avatar
nope.
OP are you sure your window is the source of your leak? the brake light seal is usually where it leaks from.
have somebody spray the hatch with a hose and sit in the hatch and look for the leak.
Old Sep 3, 2009 | 11:54 AM
InTheLBC20's Avatar
Im sorry guys, its the quarter glass that folds out, not the rear glass. My bad for not properlly (sp?) explaining myself. It leaks at the top of the passenger side quarter glass and drips down onto the floor, and into the little cubby hole thing in the armrest on that side. The window itself isnt closing tightly enough againt the weather stripping. Sorry for the confusion
Old Sep 3, 2009 | 05:09 PM
DoubleEx's Avatar
Mine does too. I live in summerville too.
Old Sep 3, 2009 | 05:23 PM
sakasaku's Avatar
i had the same problem i just fixed it
Okay Were the latch is to open and close the rear window, there is a cover pop it off and you will see to screws loosen them up ( careful they are usually stuck Dont strip ) and adjust it in and tighten them up and it will seal tighter against the stripping and wont leak in the rear window best of luck any questions pm me
Old Sep 3, 2009 | 05:33 PM
DoubleEx's Avatar
ill try it soon.
Old Sep 4, 2009 | 08:26 PM
sakasaku's Avatar
try this before you go buy weather stripping
WeakSauce92
Oct 25, 2009 12:55 PM
8dxhatchy8
19
Feb 15, 2009 02:00 PM
CRXDaddy78155
Jul 7, 2007 04:05 AM
Rex89
Jan 2, 2007 06:12 PM
