Alumninum Lug Nut Socket
Old Aug 30, 2009 | 05:05 PM
THEUSED's Avatar
Default Alumninum Lug Nut Socket
I just picket up a set of red aluminum lug nuts and Im trying to find a special lug nut socket thats meant for them so I dont scratch them up, but all I can find are the style that have plastic on the od of the socket to protect the rim, what is everyone using?
Old Aug 31, 2009 | 12:42 PM
TunerN00b's Avatar
Default Re: Alumninum Lug Nut Socket
Not the answer that you want to hear, but most of us use lug nuts that don't take damage just from being used as they were intended.
I had AL nuts for 6 months. Only ever used a torque wrench, never an impact, and they still started showing scratches and signs of external wear in 2 months. After 6 months, the threads started removing themselves from the nuts. I do 2 wheel changes a month, when I autocross (before and after the event). At that point, I decided that "racing lug nuts" aren't exactly what they claim to be, and bought a nice set of McGards. 2 years later, they look as new as the day I bought them.
I looked and looked, but never found a lug nut socket that was fully plastic on the inside. I do have a set with plastic inserts, but they just keep the very end of the nut from hitting the base of the socket, the engagement of the hex sides is still metal on metal.
Old Aug 31, 2009 | 01:12 PM
THEUSED's Avatar
Thats kinda what I figured, thanks
Old Aug 31, 2009 | 01:58 PM
siblues's Avatar
use some plastic wrap on the outside of the lugnuts that helps keep the socket/key from scratching them up.
Old Aug 31, 2009 | 02:41 PM
TunerN00b's Avatar
Wow. That's brilliant. Saran wrap FTW! (Assuming it actually fits between the nut and socket.)
Old Aug 31, 2009 | 02:58 PM
THEUSED's Avatar
Nice, i was thinkin masking tape, but thats a much better idea
F20Cdriver
Oct 7, 2011 03:32 PM
Petah
Jan 14, 2009 02:20 PM
jdmztrane
Apr 1, 2008 08:51 AM
shooitzlinh
Mar 20, 2005 06:44 PM
