4 wire 6"x9" ?
to see if its compatible to what you are trying to do. You will probably need to add separate
passive crossovers to the speakers if they can work in your application.
i have 2 crossovers in my garage. how would i go about hooking these up? im a newb when it comes to crossovers and stuff like that. im no newb when it comes to installing decks amps subs screens etc ive been doin it for a couple years. but still learning
The speakers are Bi-AMPLIFIED...meaning the high and low frequencies are driven separately by the amp. You would need the measure the impedance of each speaker side
You can take measurements and calculate it. But is there a real way to measure?
Radio Shack carries a $8.99 multimeter (even comes with batteries). I think I've bought and lost (more likely left at a friend's house) at least 4 of them over the years.
Anyone playing with electronics should have a multimeter. Really no excuse not to when they're that cheap...
If the speakers are out of a Chrysler/Dodge they are part of an Infinity system, the tweeter is driven directly off the HUs power and the woofer is boosted, [amplified] by the small amp on each speaker.
Just remove the amps and wire the two sets of terminals in parallel, the tweeter will have a cap on it for a x-over.
You can confirm this by touching the speaker terminals with any batt., [AAA, AA, C, D, or 9V] I use a 9V.
When you touch the terminals the speaker will "pop", if it is the woofer terminals the woofer cone will move, if the batt. pos.(+) is on the speakers pos.(+) terminal the cone will "pop" out, if the batt. pos.(+) terminal is on the speakers neg.(-) terminal the cone will "pop" in.
When batt. is touched on tweeter terminals the tweeter will "pop", [more like a quiet "snap"] if you pull the batt. and touch the terminals again and there is no "snap" the tweeter has a cap, reverse the batt. and you will hear the "snap" again.
You will not see the tweeter cone move. 94
