what axle for h22a eg6
Old Aug 29, 2009 | 03:27 PM
jdm_obsession88's Avatar
Default what axle for h22a eg6
I have searched but the more i do the more diffrent answers i find. I just want to know what axle i could use for passenger side h22a in eg6 with out having to buy more hasport axles. buy the way does this axle look broke?
Old Aug 29, 2009 | 03:48 PM
Anon51's Avatar
Default Re: what axle for h22a eg6
axle looks to be too short. in any case just push the shaft back into it lining up the bearings.
Old Aug 29, 2009 | 03:52 PM
VEGAN_EG's Avatar
ive been using integra axles in mine with know problems.
93-96??? correct me if im wrong on the years
Old Aug 29, 2009 | 03:57 PM
my front lower control arm nut came off last night(as pictured) and thats the damage to the axle.
Old Aug 29, 2009 | 03:58 PM
thats what im trying to find out is the yrs of integra axles. I have heard 90-91 for passenger side.
Old Aug 29, 2009 | 05:47 PM
VEGAN_EG's Avatar
Drivetrain options:
- Right 90-93 Integra Axle - edit: You must use a prelude/accord inner CV joint in order for the axle to lock into the transmission. The inner spline shaft is slightly longer for the prelude/accord than the integra. A 90-93 Integra shaft and outer CV will work with the prelude inner.
Here is a picture explaining why:
- Left Custom 92 Prelude Inner CV joint with 90-93 shaft & Outer CV joint from
Raxles for $170 1-800-257-8192
OR
- 1990 Manual Accord Intermediate Shaft
- Left and Right 90-93 Integra Axles (with prelude inner cv joint on the right axle)
OR
- Driveshaftshop.com Stage/Level 1 axles Right & Left side using prelude intermediate shaft
I personally recommend using HASport custom axles for ease of installation.
Taken from https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
Old Aug 29, 2009 | 08:10 PM
KERM1T's Avatar
i now you said not to order from hasport... but check out raxles.com they make application specific axles and if they dont make em already they will custom make them for you.. look on there website for more info or just call em... i have only heard good things from that place also....
manchildteggy
Feb 16, 2012 06:25 AM
butter99
Nov 30, 2008 12:49 PM
shox-h22a
Jun 20, 2005 08:36 AM
H22ACiViC
Mar 17, 2002 06:49 PM
