Del Sol brake help!!
Old Aug 29, 2009 | 01:19 PM
JDM KILLER's Avatar
Default Del Sol brake help!!
i have a 97 si del sol. the rear rotors and calipers and caliper brakets are all seized up and rusty and ****. but i do have a 96 integra with rear disks, does anyone know if i can just use the rear disk set up off it???
Old Aug 29, 2009 | 01:22 PM
runbycommies's Avatar
Default Re: Del Sol brake help!!
yes
Old Aug 29, 2009 | 03:01 PM
jr_deleon's Avatar
Old Aug 29, 2009 | 03:19 PM
ej1love's Avatar
sure can mister
JDM KILLER's Avatar
Thanks, what all do i need? can i just use the rotors and calipers or do i need to switch over everything?
Old Aug 29, 2009 | 04:27 PM
jr_deleon's Avatar
You can swap over whatever is seized; so calipers, rusty rotors and likely the pads, in which case you might want to put some caliper grease on the caliper pins that go into the brackets (of the replacements), new pads (if you can get them) and get some new rotors if both sets are messed up
Old Aug 29, 2009 | 04:48 PM
JDM KILLER's Avatar
thanks man, that helps out alot, i already bought new rotors but the caliper and the brakets are ****ed. the bottom caliper pen wont move at all so only the top part of the pad hits the rotor
Old Aug 29, 2009 | 06:09 PM
jr_deleon's Avatar
Grease those pins up good before you put it together, also check the pin seals (the rubbers) for any cracks or tears that would allow water in and you should be golden
Old Aug 29, 2009 | 06:22 PM
JDM KILLER's Avatar
thanks bro i will try it out
the_racerx
Suspension & Brakes
Aug 25, 2013 11:44 PM
shadhman
Jul 23, 2008 11:52 PM
ivicr
11
Oct 5, 2006 10:03 PM
DelSeeYa
Nov 28, 2005 10:12 AM
memphisraines26
May 14, 2003 07:02 PM
