Radiator Cores?
Old Aug 29, 2009 | 09:27 AM
3rdshift's Avatar
Default Radiator Cores?
Can anyone get name brand radiator cores? i would rather just buy a core i need one similar in size to a half core for a 00 civic
Old Aug 29, 2009 | 07:59 PM
KFMRC's Avatar
Default Re: Radiator Cores?
If you have a good used rad already and you need a shorter height cross flow core then just cut the plastic tanks off and then cut the core to the height you can use cutting thru the center of a row of tubes. If you have the height and want to make the rad symetrical then cut from the top and bottom to get the correct height. Otherwise just cut 1 side and the you only need to make 1 pc to cover the area where you cut the tubes. I usually bend a c shapped pc of .040-050 aluminum. I weld it on after the tanks are welded. Unfortunately I and many others find it cheaper to cut a new replacement rad apart then to buy a core alone. You cna get various width (header to header) dimensions if you look and do some research.
Old Aug 29, 2009 | 09:17 PM
Top Ramen's Avatar
Several companies sell cores. Try the ones that specialize in custom rods, like BeCool.
Old Sep 2, 2009 | 11:56 PM
ROTARY's Avatar
the only well known brand that sells radiator cores without end tanks is BIC- Bell Intercoolers.
Last edited by ROTARY; Sep 3, 2009 at 12:49 AM. Reason: added the word (radiator) to avoid confusion.
Old Sep 3, 2009 | 03:58 AM
weiRtech's Avatar
OG Fabricator
do a search. this has been discussed a few times now.
rudebwoy
May 11, 2014 07:43 PM
joemonster
Oct 22, 2009 08:22 AM
Muckman
Welding / Fabrication
12
Mar 18, 2009 02:52 PM
Muckman
10
Sep 18, 2008 03:03 PM
hotimportcrx
10
Mar 27, 2005 06:54 PM
