Question: Stock Si Rims + Wheel Spacers
I will be getting my Si rims powdercoated in Gunmetal until I save up enough for a nice set of wheels.
My question is what size wheel spacers should I use to make the rims flush, or atleast close to it. And will I need extended studs?
Ryan
Ryan
5 mm should be close.
that would put you around a +40 offset.
u can go 5 more and go 35. i think its about flush at 35.
but you're going to need open end lug nuts and extended studs to go out that far
on spacers.
on spacers.
The HFP is a .8-1" drop, normally settles around 1-1.2" at best. This should leave you with enough gap to go flush but I'm not 100%. My sportlines are initial 1.4" drop and settled closer to 1.6" drop, I have a slight tuck on my wheels at that level.
^ i second that. my front wheels on 225's were tucked pretty good.
now im on 215 and its barely tucked. i just wish the rear was lower.
but thats why im getting coilovers.
i-VTEC DOHC -- thanks
