Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
02 TL Ball Joint
Old Aug 29, 2009 | 08:33 AM
93gsrcoupe's Avatar
Default 02 TL Ball Joint
Anyone ever replaced a front left ball joint on a 2002 TL? I've never worked on a TL suspension, is there an upper and lower ball joint? Do they have to be pressed out? Any diagrams would be helpful.
Old Sep 1, 2009 | 12:49 AM
fourthgenhatchB17's Avatar
Default Re: 02 TL Ball Joint
Front suspension is pretty much the same basic design as the Civic/Integra. There is an upper/lower ball joint. They can typically be removed with a bfh (big f'n hammer) after the circlip is removed. Install should be done with a press or a large C clamp with an adapter for ball joints. Pretty easy and straightforward really..
Old Sep 2, 2009 | 02:11 AM
YeuEmMaiMai's Avatar
use a fork to pry them out. you insert the fork and then hit it with a hammer a 2 lb sledge should do it
Old Sep 2, 2009 | 02:14 AM
Originally Posted by fourthgenhatchB17
Front suspension is pretty much the same basic design as the Civic (pre Mc Pherson strut) and Integra. There is an upper/lower ball joint. They can typically be removed with a bfh (big f'n hammer) after the circlip is removed. Install should be done with a press or a large C clamp with an adapter for ball joints. Pretty easy and straightforward really..
there fixed it for you
Old Sep 3, 2009 | 12:42 PM
Do you realize what hes asking? Replacement of the ball joint, not just separating it from the knuckle. BFH works great for separation too though (when hit in the right spot), pickle forks are for hacks. My directions are assuming he has the knuckle already separated and on the work bench. UCA ball joint is also the same procedure when sitting on the bench.
Where you added MacPherson in my quote implies the Civic is pre MacPherson and the Integra is not.
Old Sep 3, 2009 | 07:10 PM
lol the only hack is a person who would pound on the car suspension to remove a balljoint. the fork removed the pounding on the suspension. Also he never said he took it off. matter of fact if you had read what he said "I have never worked on a TL suspension before"
and before you try to be intelligent, you might want to realise that pre mc pherson strut civics are indeed double wishbone just like the TL......and no it does not imply what you are thinking- it means exactly what it says civics that are pre mc pherson struts have the same basic suspension as the TL
Old Sep 3, 2009 | 10:57 PM
Re-read what I wrote. You are simply overanalyzing, why am I not surprised... He asked how to remove a ball joint, not separate it. I simply answered the question. Here, this makes more sense since you cant seem to figure it out: Where you added MacPherson in my quote says the Civic is pre MacPherson (true) and implies the Integra is not (false).
Using a pickle fork in conjunction with a bfh can also result is lots of harsh and forceful pounding. The suspension can easily handle either method. Its strictly my opinion, dont agree? Dont care. And I was being nice at first, but dont edit my words. Its really not allowed, unless you're a moderator?
No more time spent on this, unsubscribed.
Old Sep 12, 2009 | 05:14 PM
soon2bdropped's Avatar
theres a nice kit at work called lamba. help you remove and press the new balljoint in. what i found to work remove the balljoint from knuckle buy rippin the LBJ boot off and using an air hammer to prry it out from knuckle
arielb1
Oct 31, 2008 12:29 PM
Menace2Society
Dec 15, 2007 06:23 PM
vtechrex
Jan 31, 2006 09:06 PM
carl_aka_carlos
Feb 9, 2003 10:14 PM
civbeater90
Jul 28, 2002 08:46 PM
