tubular log manifold turbo kit? and turbo/clutch/injector advice
Old Aug 28, 2009 | 04:57 PM
TooSmooth's Avatar
Default tubular log manifold turbo kit? and turbo/clutch/injector advice
im looking to pick up a turbo kit for my ls integra with a gsr swap, i also want to keep my ps/ac/ and full radiator... im also trying to achieve quick spool and good mid range power.. i did some research and think a tubular log mani is the best option... is there anyplace that sells a turbo kit like afi/synapse with a log manifold?
also what turbo,clutch, and fuel injectors should i be running? im looking for 8-9 psi for 275-310hp... ive done some research on my friends h-t account but im just trying to get some exact advice
i plan on running hondata s300/ neptune and a walbro 255 pump, and 3 inch downpipe back exhaust
Old Aug 28, 2009 | 05:17 PM
4drhoar's Avatar
Default Re: tubular log manifold turbo kit? and turbo/clutch/injector advice
ebay cast mani 66 bucks retains a/c and power steering and will make all the power u need
Old Aug 28, 2009 | 08:08 PM
TooSmooth's Avatar
http://www.go-autoworks-store.com/gotutusy1.html
will i be able to make 300 with a 2.5 down pipe and catback? they only make a ac version with 2.5
Old Aug 30, 2009 | 07:17 AM
Turbo-LS's Avatar
tubular log manifolds suck, you better off with a cast log. With a tubular log all the runners run into eachother and create alot of exhaust back pressure at least with a cast log the runners all somewhat get directed to the turbo and not right at one another so it will flow better.
There are plenty of manifolds out there that work for a/c and p/s. Im currently running the SPA cast topmount on my gsr and it has huge runners a great design and flows very well. Ive run tubular top mounts and ramhorns before and would say its comperable in performance as a turbular topmount. Im not saying its exact but close and allow syou to retain a/c and p/s.
Old Aug 30, 2009 | 02:27 PM
TooSmooth's Avatar
what do i need to make 320 at 10lbs
Old Aug 30, 2009 | 04:00 PM
b20beast83's Avatar
gt35 or high reading dyno
Old Sep 27, 2009 | 06:17 PM
4drhoar's Avatar
nitrous
Old Sep 27, 2009 | 08:03 PM
ACTION JACTION's Avatar
Ramhorn manifold
S366 ETT
Pro 1 cams
420_EM1
Dec 21, 2013 03:22 PM
dtarvin
Jan 7, 2009 10:45 AM
freakie
Sep 16, 2007 10:53 PM
ser13
Nov 27, 2006 04:12 PM
DIRTYsouthBB6
Mar 19, 2006 02:53 PM
