Stupid Wiring In the ITR
Old Aug 28, 2009 | 10:37 AM
watisjdm's Avatar
Icon3 Stupid Wiring In the ITR
Ok so i replaced the jdm rhd dash harness with a new jdm rhd dash harness and well my luck has been just as shitty
the car runs and seems to work fine other than some high idling and what not but my main problem is the cluster and pretty much the dash
1. cluster problems........the tach doesnt work at alll
2. temp gauge goes all the way to hot when crank car up and when i let the ebrake down it goes back to normal
3. i cant tell if the gas gauge works or not cause i was told there was about 1 gallon of gas in the car so idk hahaha
4. the radio is getting no power at all to it
5. the turn signals dont work
6. hazards dont work
7. there are a couple plugs underneath the steering column that arent plugged up but arent sure if they goto anything
heres the pics of the plugs that arent plugged up
im just trying to figure all this out before i start actually driving it and what not...the radio and climate control and **** not working doesnt bother me i just need the tach and what not on the gauge cluster working
if someone could pleaseeeeeee help me
also this relay ground wasnt grounded just seeing if thats a problem prolly
Old Aug 28, 2009 | 03:29 PM
Shalom's Avatar
Default Re: Stupid Wiring In the ITR
What year car did the dashboard harness come out of, and what year car did the cluster come off of? IIRC the gauge cluster plugs are different depending on years, and one of those plugs you're holding in pic looks like one of the gauge cluster plugs. How many plugs are plugged into your cluster?
Old Aug 28, 2009 | 03:53 PM
watisjdm's Avatar
naw the plugs for the cluster are blue and there is two plugged into the cluster right now
the dash harness came from a obd2 car not really sure on the year and the cluster i think came outta a 96 and yeah....idk im just trying to figure it out
Old Aug 29, 2009 | 09:47 AM
Ramirez428's Avatar
Green one either connects to the front of the actual fuse box or the rear, the clear 4 pin plug should go to the relay in the front of the fuse box( I think it controls the horn) the grey plug should mount on the top of the fuse box and connect to the dash harness. If it doesn't then it's mostlikely the one that connects to the rear harness
Old Aug 29, 2009 | 10:46 AM
mtny's Avatar
I just skimmed the thread.
It sounds like the gauge cluster and the harness are different year models.
I put a 98 cluster in my 00 GSR and it did the exact same things.
Old Aug 29, 2009 | 11:48 AM
nsxtasy's Avatar
H-T Order of Merit
When you're using wiring harnesses in a car that was never designed to use them, it's not the wiring that's stupid.
Old Aug 29, 2009 | 02:45 PM
watisjdm's Avatar
huh
Old Aug 29, 2009 | 03:10 PM
Micha's Avatar
FAILWGN
Get ahold of the guy you bought the car from. He basically rebuilt that car from the ground up.
Old Aug 29, 2009 | 08:31 PM
watisjdm's Avatar
yeah pretty much...good idea
Old Aug 29, 2009 | 08:43 PM
Micha's Avatar
FAILWGN
Sorry. not good with wiring. i need to get good soon.
Old Aug 30, 2009 | 01:21 PM
Brice.Hayden's Avatar
You could start with your english and grammar first
Robbie those pics are awful. I have some other clusters to use if you need some. lemme know
Old Aug 30, 2009 | 06:45 PM
watisjdm's Avatar
will do, thanks
Crx_Nando
Jul 1, 2015 06:57 PM
supermeister
Feb 4, 2009 01:14 PM
91Hatcher
Oct 24, 2008 09:54 PM
sohcdestruction
Feb 14, 2008 12:36 PM
Origin
15
Sep 23, 2003 03:38 PM
