GSR Brakes on civic question.
Old Aug 26, 2002 | 02:55 PM
HXMan's Avatar
Default GSR Brakes on civic question.
Ok, this is what I heard I need to do while using integra brakes. I will need to use 99-00 Si knuckles, or if I want to have camber trouble I can use the i ntegra knuckles...
I was kinda hoping the calipers would bolt right on...but if they don't the swap will probably cost more then I wanted to spend right now.
So, is that info true??
Old Aug 26, 2002 | 03:13 PM
Spade's Avatar
Default Re: GSR Brakes on civic question. (HXMan)
Just get the trailing arms with everything attached from the Integra (any integra there all the same size) and use your Control arms. EDIT: FOr the back.
Front....get EX brakes and an Integra caliper. Same size disks.
You do want a Master Cylinder and booster from as well as a prop. valve.
Oh and one more thing.....SEARCH
[Modified by Spade, 4:14 PM 8/26/2002]
Old Aug 26, 2002 | 04:22 PM
tonyxcom's Avatar
You can use the Integra knuckles without issue. Most of us have our cars lowered, so all it will do is take away some negative camber.
When I installed mine, I installed a skunk2 camber kit (only so I can adjust it to where I want and have it even) at the same time, so I dont know how much camber the integ knuckles will take off a 6Gen civic.
I can only see it being a problem if your car is stock height, in which case it will put your front wheels in postive camber.
Old Aug 26, 2002 | 05:29 PM
HXMan's Avatar
Default Re: GSR Brakes on civic question. (Spade)
Lol...I did a seach spade. I just wanted to confirm the info I had.
I already have installed a 15/16's master cylinder, 4040 prop valve, Si rear discs, and integra parking brake cables.
Tony: I am planning on lowering my car anytime now....maybe I will have to look into those skunk camber correctors.
[Modified by HXMan, 8:30 PM 8/26/2002]
Old Aug 26, 2002 | 06:24 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
4G car, front GSR brakes, lowered. front left -1.87, front right -1.9, no camber adjusting done. that is with the teg knuckle and upper control arm. as far as i can see there is no basis to the myth that the teg's knuckles cannot be used on civic platform. of course my car was lowered before i did the brakes. i even think that the teg's upper control arms have more positive caster than the civic ones, although i cannot be sure at this moment as i haven't seen both of them side-by-side in a while (since i did my bushings).
stan
Old Aug 26, 2002 | 08:01 PM
tonyxcom's Avatar
Default Re: GSR Brakes on civic question. (90crxsi)
4G car,
6G front suspension geometry is a little different then a 5G, Integ and I am sure 4G as well.
Old Aug 26, 2002 | 08:52 PM
Default Re: GSR Brakes on civic question. (tonyxcom)
true enough, the lower control arm is different, but honda tends to keep things simple and easy to mass produce. i don't see why the similarities in integra/civic chassis would stop on the 4G.
stan
Old Aug 27, 2002 | 12:47 PM
HXMan's Avatar
Hmmmm.....
808rex
Jul 2, 2009 07:39 PM
UrbanEh
Feb 1, 2007 03:35 AM
UrbanEh
Suspension & Brakes
Feb 1, 2007 03:34 AM
littlegreenb18
Jul 9, 2006 02:46 PM
bleedblue94
May 15, 2006 11:45 AM
