sohc rebuild????
Old Aug 28, 2009 | 12:44 AM
prolifik22's Avatar
Default sohc rebuild????
well i have a y8 and it has bad bearings and the crank is also scard so i was wondering what cranks work with the block like if there interchangeable???? juz curious if anything else works with the sohc blocks.. also is there a place i can get a crank and bearings at online or localy? thnx for ur time ..good day to all
Old Aug 28, 2009 | 12:48 AM
98civdx's Avatar
Master Detailer
Default Re: sohc rebuild????
you could always throw a y7, y8 block in it, and then just put your y8 head on it.
you could put any y8 part in, and im pretty sure y7 cranks are the same.
you could use oem bearing, what would use, our there is king and acl
Old Aug 28, 2009 | 01:06 AM
prolifik22's Avatar
I know the parts are the same but like is there a diffrence from a z6 and if there was a bad bearing what are my options to redoin the motor or what not..
Old Aug 28, 2009 | 01:10 AM
98civdx's Avatar
Master Detailer
i cant answer on the differnces bewteen the z6, i just dont know.
first off i would have a shop check your crank to see if its even fixable.
if it is use that, if not id just grab another y8 or y7 crank.
or just swap a full short block in.
Old Aug 28, 2009 | 03:19 AM
hondamark35's Avatar
Originally Posted by 98civdx
...or just swap a full short block in.
BINGO!
the only time i would say "go ahead and rebuild" is if you had plans to do internal work anyway, like boring over, or droping in forged rods/pistons. but like 98civdx said, find yourself an unmolested Y8 and just swap it in.
unless you can do machine work yourself, for free.. you can end up paying the same or more to recondition your engine as you would for a engine you buy from a salvage yard or individual.
i do know it's a good idea to get some sort of reciept for the engine, and a VIN from the original car so you don't get blamed for having stolen property .
Old Aug 29, 2009 | 12:28 AM
prolifik22's Avatar
thnx all and its juz out of curiosity but yea if it was that easy to find a block i would but i want to rebuild it thats y i was askin
Old Aug 29, 2009 | 05:21 AM
apexi_rsx's Avatar
Z6 cant has 2 oil holes int he crank vs the y8 with just 1. i personally like the z6 bottom end. ur y8 head would snap rite on it. P n P
Old Sep 1, 2009 | 06:03 PM
prolifik22's Avatar
i look'd up a rubuild kit and there showin the same part # for the z6 and the y8
Old Sep 1, 2009 | 06:06 PM
DCRB's Avatar
that is true. the z6 crank WILL bolt into your stock y8 and function the same (only better because of more oil to the bearings)
Old Sep 1, 2009 | 06:16 PM
prolifik22's Avatar
so they r interchangeable??
thnx for the knowledge
slammedsedans
Feb 12, 2015 06:54 PM
grumblemarc
Mar 30, 2011 04:03 AM
iheartmyej8
12
Jan 7, 2007 07:53 PM
d16dcoe45
Oct 4, 2006 01:03 PM
5thgen
Sep 8, 2003 09:16 PM
