Is there a problem with my fuel gauge?
Old Aug 27, 2009 | 11:48 PM
offspringpunk14's Avatar
Default Is there a problem with my fuel gauge?
Ok so I just got this car tonight, its a 93 civic hatch with a b16. I was driving it around and noticed that the fuel gauge seems to move alot, I didnt know if this is normal or anything but I just seemed to drop down and then go back up alot, sometimes faster than others. Just let me know if there is a fix to this.
Old Aug 28, 2009 | 04:09 AM
tercel95's Avatar
Default Re: Is there a problem with my fuel gauge?
Normal...
Old Aug 28, 2009 | 04:58 AM
honda.lioness's Avatar
Ditto, normal for circa 1990 Honda Civics.
Old Aug 28, 2009 | 06:51 AM
JasonYo's Avatar
Yeah, try taking a big right turn like a highway on/off ramp. You're fuel guage will probably drop quite a bit.
Old Aug 28, 2009 | 07:34 AM
300whpej's Avatar
normal for every civic i have ever been in from 89-00. take a off ramp at like 40ish mph and watch it then. just know that there is constant fluctuation in your gas needle
Old Aug 28, 2009 | 07:44 AM
jooky5's Avatar
especially under half a tank.. the needle goes crazy
Old Aug 28, 2009 | 12:50 PM
[QUOTE]especially under half a tank.. the needle goes crazy/QUOTE]
+1 happened to me today. What do you guys normally see to a tank on this kind of car. With mixed driving.
Old Aug 28, 2009 | 01:00 PM
Vindicator9000's Avatar
318 Curves, 11 miles
B16 in a 93 hatch? I'd say that if you're not getting above 330/tank (around 30mpg), you're not trying. I'm getting that on a B18 in an EK.
Old Aug 28, 2009 | 01:04 PM
98civdx's Avatar
Master Detailer
yep its normally due to the fact you have no baffles in your tank, there for gas moves around alot.
Old Aug 28, 2009 | 01:08 PM
ok. I have been kinda beating on it because i just got it last night. I put 15 dollars in it and that almost filled it and i have like 130 on a half tank. the car does need a tune up which will be done this week. Any recomendations on plugs and wires? Also what should the gap be? And anything else I should change?
Old Aug 28, 2009 | 01:19 PM
blueg6's Avatar
i get like 280 to a tank in my b18c eg. but thats with me hitting vtec all the time.
Old Aug 29, 2009 | 04:53 PM
98civdx's Avatar
Master Detailer
ngk plugs, ngk wires, or oem, or whatever the store has thats not the cheepest pos.
Old Aug 29, 2009 | 05:06 PM
namewasdallas's Avatar
magnacore wires, ngk plugs. but my gas gauge 98 ex does the same thing its common
Old Aug 29, 2009 | 05:51 PM
earlylocks's Avatar
very normal for a civic!
vrrodri
Jun 29, 2011 05:32 AM
bobbybo213
Sep 11, 2008 09:39 AM
Rikaro
Aug 31, 2007 04:44 PM
aberle99
Jul 11, 2007 10:29 AM
E dwinbon G
10
May 21, 2004 08:02 PM
