weird scratching noise?
Old Aug 27, 2009 | 10:40 PM
spens 91 Ef's Avatar
Default weird scratching noise?
i have a weird scratching noise on my passenger side wheel well ive taken off my tire to see if anything was rubbing didnt see anything checked my hub bolt and made sure it was tight enough, also check my axle boots and the look fine no tears it usually only does it in first when i rev my car high
Old Aug 27, 2009 | 10:46 PM
BiG ChOr!Zo's Avatar
Default Re: weird scratching noise?
check the dust shield since it might be rubbing against the brake rotor...!!!
Old Aug 27, 2009 | 10:50 PM
checked that first and have heard that many times in different hondas
Old Aug 28, 2009 | 12:15 AM
jenifertom90's Avatar
you may be having a problem with the spring or nuts...check it out...that may have become a bit loose....
Old Aug 28, 2009 | 12:45 AM
ya thats a possability ill check that, maybe its my autozone strut ill look further into and make sure everythings tight
Old Aug 28, 2009 | 01:58 PM
johnnyonth3spot's Avatar
what about a brake clip? When does the noise pop up?
Old Aug 28, 2009 | 08:28 PM
i had my brake caliper popping for a while and the top of it was grinding away finally fixed that
Old Aug 28, 2009 | 10:43 PM
how about motor mount?
90ED6LSV
Aug 29, 2019 08:14 PM
'97 RS Teg
Sep 26, 2013 12:18 PM
djtony5
Apr 14, 2007 06:40 PM
BlueIntegraBoy
Aug 19, 2005 03:46 PM
.M.
May 19, 2005 01:03 PM
