cluster ....light help...
ok well i have an eg8 (92 4 door eg) my cluster lights do not go on at all i want to know if they have a fuse...or what can be wrong...i pulled out the cluster and foudn 2 green plugs disconnected...the cluster has everythinggg connected and i couldnt find where 2 connect those 2 plugs (are they my problem) is that normal?? please
lmk and thanx htech
lmk and thanx htech
Remove the dimmer switch in the dash, unplug the connector, and jump the red wire to the black wire in the connector. Do the dash lights now work with the light switch on? If so, replace the dimmer switch.
sol-oto
Jun 17, 2018 08:56 AM
