92 eg hatch. Cluster issues
Hello my cluster works but the lights that suppose to light up
When it's dark out don't come on I tryed two cluster... fuel gauge e brake clock battery light work. Blinkers work blue light for high beam work. Just the lights that light up rpm speed won't work. Lights are good. Fuses are good all grounds are on....
Stuck ..,.....
92 hatch manual
Different dash but looks exactly same as old one
Like to figure it out before I swap harnesses
Stuck ..,.....
92 hatch manual
Re: 92 eg hatch. Cluster issues
Got some help from a friend dimmer switch
Is what was wrong I violated it an seen a few flashes
I had an extra but that was also bad. Either clean it or a new switch
If anyone else runs into this issue
Is there an actual question here? Additionally have you taken a voltmeter and checked to see if there is power at the illumination wire to the cluster itself?
lluks_844
06-01-2007 05:01 PM
bonstokLS
03-31-2006 09:04 AM
