brake light on. 91 integra
Old Aug 27, 2009 | 07:05 PM
jhammond_82's Avatar
Reject Papi
Default brake light on. 91 integra
lately i've been having an issue with my brake system warning light coming on. it doesn't get solid red, it's more like a light red, and it comes on and shuts off from time to time. i have no leaks anywhere. brakes feel perfectly fine still. and, the master cylinder is full. does anyone know why this would be happening?
unrelated to the issue, is my check engine light. no codes, just a check engine light. now, yesterday i cleaned up my engine bay by removing the power steering and air conditioning. would removing air conditioning and the wires and relays related to that cause a check engine light? thank you.
Old Aug 27, 2009 | 09:28 PM
jDMJeRk's Avatar
Default Re: brake light on. 91 integra
If the brake light it on chances are your brakes need to be services regardless of how well they work.
The CEL shouldn't throw a code for removing your a/c and p/s... At least it didnt on mine years ago...
Old Aug 27, 2009 | 09:55 PM
Hydro_Da's Avatar
i got the same problem but it also started happening with the oil pressure light. mine goes on but dims. then goes off by itself. at random intervals too. so bump for an answer.
Old Aug 28, 2009 | 05:58 AM
Reject Papi
thats what i figured, they need service. but, what exactly needs servicing? lol. my car does have abs and the abs light is always on, blown fuse. and only recently did the actual brake warning light start to come on.
Old Aug 28, 2009 | 07:30 AM
Circusraven's Avatar
Have you checked you brake cylinder reservoir cap? even possibley the two little wire hook-ups attached to the cap. If they aren't plugged in right, they may be sending a false signal.
Old Aug 28, 2009 | 02:27 PM
teknohed's Avatar
Circusraven has a good suggestion. I had a problem like this in my 91 when my alternator was going bad. I guess the car would shut down "non essential" systems including the anti lock breaking system. This would cause my anti lock and brake lights to come on but would dim out as I'd get up to freeway speed and the power would start to build up, you might get a voltometer and make sure your alternator is charging your battery effectively.
egmatt93
Nov 22, 2006 10:58 PM
m.c.
May 2, 2006 08:59 AM
mandyb
Feb 25, 2006 02:56 PM
d98clturbo
Acura TL, RL & ZDX
Jun 30, 2005 11:28 AM
gejuhasz
Sep 16, 2002 10:36 PM
