Transmission & Drivetrain Gearboxes, Differentials, Clutches
Will gsr gears fit in my B16 tranny
Old Aug 27, 2009 | 02:32 PM
JDM Tater's Avatar
Default Will gsr gears fit in my B16 tranny
i heard that u can take the 1st and 3rd gear from a gsr and the and the 2nd and 4th from the B16 and the b18b1 5th gear and make a killer tranny
Old Aug 27, 2009 | 06:07 PM
Honda Bull's Avatar
Default Re: Will gsr gears fit in my B16 tranny
1. 1st gears are ALL the same for hydro B-series.
2. 1st and 2nd gear sets include the mainshaft, so differing 1st and 2nd from what Honda offered is not an option.
3. For the most part, you can do whatever you want with the other three gears.
Basically, what you posted is a B16 trans with a GSR 3rd and LS 5th. If you want to do anything, just put the LS 5th in the B16 trans and be done with it. Don't even bother with 3rd. It's already fine.
Old Aug 27, 2009 | 06:16 PM
JDM Tater's Avatar
you sure cause i had a guy tell me he had his like that but u know how that goes
Old Aug 27, 2009 | 07:29 PM
Aquafina's Avatar
B16 2nd into GSR 3rd is going to suck.
Old Aug 27, 2009 | 07:54 PM
JDM Tater's Avatar
i mean i seen it and the guy ran like low 9s with nothin on the car
Old Aug 28, 2009 | 07:09 AM
Honda Bull's Avatar
I am sure. Like I said, all 1st gears are the same, so it doesn't matter with that.
And I'm presuming low 9's in the 1/8th mile? Which means... stock GSR swap on okay tires and anything but an LS trans. Nothing crazy about that.
Old Sep 2, 2009 | 09:10 AM
linkdeezie's Avatar
hondabull is right. ALL b series first gear are the same...from the integra LS to the type r, so changing them will be idiotic. Its the 3rd and 5th gears that u wanna isolate because 3rd is where ur engine/transmission will work the hardest (other than first gear) and 5 for cruising. So its up to u what 3rd gear u use, and the LS fifth is good for highway cruising without high revving and burning gas
Old Sep 9, 2009 | 02:27 PM
EatPho's Avatar
New User
wht about using ls gears with b16 or type r final drive? for a boosted drag tranny
Old Sep 9, 2009 | 02:28 PM
EatPho's Avatar
New User
wow not possible unless 1/8 track.
Old Sep 10, 2009 | 08:22 AM
unusual71's Avatar
yes its possible to swap to a b16 or type r final drive but you will also need to swap the diff. wherever i see the type r final drive set it comes with the output shaft and first gear. anyone know what is different about the first gear since all b-series trannys have the same ratio for first?
blaccrex
Jan 14, 2012 12:44 PM
jchrm80
Sep 24, 2009 08:53 PM
Jintegragsr97
Sep 15, 2008 01:59 PM
GTWITIT
Apr 27, 2005 09:56 AM
