SRS Light
Old Aug 27, 2009 | 12:11 PM
grape1161's Avatar
Default SRS Light
Does anyone have a pic of the fuse box underneath the dash on a 93 Del Sol ? I have been trying to take care of the SRS light (Aftermarket wheel) on my car, and the pics that go with it doesn't look anything like mine, and I swear I can't find the MES. I went looking for the dummy harness on the fuse box, but I just can't seem to find it either. This is starting to give me a migraine !!! ANY help or pics will greatly be appreciated . . .
Old Aug 27, 2009 | 02:11 PM
ej1love's Avatar
Default Re: SRS Light
they go to a box behind the console on the floor. at least its like that on my ej1...
Old Aug 27, 2009 | 02:58 PM
vvboy's Avatar
under the dash on driver side located on the fuse box there a yellow where on the fuse box unplug that wire then find two speaker wire to plug the yellow with two speaker wire then at the end of the speaker wire put then together and turn the ignition key on but dont start it.then srs light should blink two time then turn ignition off plug yellow back to the fuse box you r done light is off!
Old Aug 28, 2009 | 04:13 PM
grape1161's Avatar
I did that, but it didn't blink, go off or anything else for that matter. It's more of a annoyance than anything, but I would like to have it go off
Old Aug 28, 2009 | 06:28 PM
jasoncrashtech's Avatar
have the airbags in your car gone off or something ?
Old Aug 28, 2009 | 08:07 PM
vvboy's Avatar
mybe this web site will help you explane it better if not then your car f up!
www.geocities.com/myintegra96/srs.html
How To Reset The SRS Indicator LightAug 19, 2006 ... 12) If the SRS light comes back on (assuming you reset the SRS correctly and the ... 94 Honda Civic EX. 95 Honda Civic DX 96 Honda Civic DX ...
www.geocities.com/myintegra96/srs.html - Cached - Similar
Old Aug 29, 2009 | 07:17 PM
grape1161's Avatar
I have a aftermarket steering wheel, and I just want that annoying light to go away. Short of taking the dash apart and taking the light out (not too mechanical, just know enough to make it dangerous) I don't know what to do . .
Old Aug 30, 2009 | 03:55 PM
vvboy's Avatar
if you want the SRS light to go away JUST TAHE OUT THE CLUSTER AND REMOVE THE SRS LIGHT BUBS OUT.i think you should get a stock steering wheel then the srs light might turn off
Old Aug 30, 2009 | 07:59 PM
there isn't a way around that man, if you remove the clock spring or unplug the air bag the srs light will stay on. you'll haft to pull the bulb. i don't like stuff like that but if your making a change in steering wheel it's tuff to get around that in some cases. (non oem)
James1031
Sep 22, 2018 12:59 PM
lowandloud
Feb 12, 2012 06:06 PM
zXeX
Sep 2, 2009 07:34 PM
tpot90
Oct 3, 2007 07:00 AM
FusionITR
Mar 3, 2002 06:14 PM
