B20 Vtec ignition timing?
If you can datalog, setting the timing is as simple as setting the base timing to read the same as what the ECU is showing at idle. If not, start at 12 Degrees BTDC. Get the car to a dyno and advance the timing 2 degrees at a time until you get the best overall power curve, without knock. Ideally, you will replace your generic chip with a custom dyno tuned chip program tailored to your car. Dyno tuning=
JDubya
Jan 25, 2003 02:30 PM
