question on starter
wasup guys i have a question when i try to start the car it just click dont even try to turn over whats the problem? cant be my started because just replace it with a new one thanks.....
theres alot of reasons why this would happen u should check the ground cables that connect to the battery sometimes they become caroded or rusted and power wont flow right thats the positive and negative cables, also check the fuses under the hood thats always a possibility
Also do you have acessories when u turn the key and u should check ur battery too if u have and air intake u might of screwed the positive terminal if both the pipe and the terminal touched and happened to me also if u get stuck in a sticky situation if u have a manual trans push start it.....good luck
WTB AUTO EK
Jul 5, 2005 11:05 AM
RedStarGsr
Jan 26, 2004 06:25 PM
