b16 head!?!?
Old Aug 26, 2009 | 08:37 PM
BuiltCivic99's Avatar
Default b16 head!?!?
ok so i snapped my timing belt and im pretty sure i bent a valve im doing a compression test soon but im wondering if it is bent..what should i do its a JDM b16a head with cams but if its ****ed and unfixable what are good heads b18's possibly ls/vtec? or just get a stock b16a head and swap out my cams..
Old Aug 26, 2009 | 09:23 PM
Rok_Stok's Avatar
Default Re: b16 head!?!?
I'm pretty sure you bent a valve too. I bent 2, in a h22.
Of course the best head is the Type-R since it comes mildly ported and polished from the factory and has a much stronger valvetrain. The GSR has smaller combustion chambers which will add roughly 0.3 to your compression ratio. This sounds like a good time to plan out a build.
Although my old H22 has two bent valves, the head was in perfect shape, so I just replaced the valves and kept the head.
Old Aug 27, 2009 | 03:21 AM
Rock_Henry1234's Avatar
if the timing belt snapped and you bent valves, it is repairable via a machine shop. i personallly run the ls/vtec and it does great.
PURPLERANGER
Aug 9, 2014 05:43 AM
stockF22B1
Dec 15, 2012 07:08 PM
baynedo
Mid-Atlantic (Sales)
May 27, 2011 01:55 PM
Superdragr45
23
Jul 21, 2005 12:03 AM
RenzoDaPlayboi
Jun 13, 2005 05:17 PM
