1993 Civic DX Sedan 5 spd - Bump starts- not turning over.... No, Im not stupid.. ;)
Checked Battery- Voltage is good
Checked starter, safe side- replaced it.
Checked for fuel pump cycle at "On position", fuel pump cycles. (Obviously if bump start works).
Checked all grounds, all wires to starter- all connected and clean. Engine is original.
Main relay is functional, removed from working vehicle.
I tested continuity between the Iggy switch and it was negative- I got nothing.... so should I throw more money at it assuming the iggy switch randomly went? Or...
PS- Car is my brothers, he drove it to dinner just fine and for past 2 weeks, randomly in retsaurant parking lot, will not start. It does not crank, no nada but all the power acc. work. (radio, lights, dash lights, fuel pump..).
Could it possible be the CPS? But then it would still turn over, would it? Or at least try...?
there is also a spade connector on the starter, its the signal wire, I have seen them come off before giving the same results that you have
gl
gl
machaux
Nov 27, 2016 01:55 PM
