Spoon radiator cap, how does it help?
Old Aug 26, 2002 | 12:53 PM
VTEC-DA's Avatar
Default Spoon radiator cap, how does it help?
I looked and looked but could find the answer I wanted. How does have a higher pressure radiator cap increase cooling ability? If anyone can, I want the technical answer.
Old Aug 26, 2002 | 12:54 PM
Spade's Avatar
Default Re: Spoon radiator cap, how does it help? (gen3gsr)
Increases pressure inside the cooling system....higher pressure = higher boiling point
Old Aug 26, 2002 | 01:39 PM
martini's Avatar
Default Re: Spoon radiator cap, how does it help? (Spade)
I believe the numbers are every 1PSI raised in the cooling system is 5 degrees the boiling point is raised.
Do you need to know how a radiator cap works? maybe that'll help you understand easier?
Old Aug 26, 2002 | 01:49 PM
VTEC-DA's Avatar
Default Re: Spoon radiator cap, how does it help? (martini)
Sure, if someone will explain it.
Old Aug 26, 2002 | 03:01 PM
martini's Avatar
well basically, the radiator cap is there to hold the pressure. It's spring loaded, and set at a certain pressure. When that pressure is exceeded, the cap opens up, and the pressure pushes the coolant out into your overflow tank. Here's a quick little writeup: http://www.howstuffworks.com/cooling-system7.htm Sometimes it will overflow if you have too much coolant in your system, sometimes it will overflow if you are overheating (coolant expands when it gets hotter), or most frequently, I would say, it overflows when the cap is broken..
The more pressure the cap will hold in, the higher your boiling point will be. But you have to make sure the rest of your cooling system is up to snuff (hoses, radiator end tanks, etc, etc..)
Old Aug 26, 2002 | 06:45 PM
PyroVTEC's Avatar
New User
GReddy also has a radiator cap, for $21 I think. 1.3bar vs. 1.1 bar for the stock cap.
Old Aug 26, 2002 | 11:47 PM
D16Z6racing's Avatar
Default Re: Spoon radiator cap, how does it help? (PyroVTEC)
I bought my Mugen cap cause it was Mugen. Got it for $27 new. I had no clue that it was helping in any way.
macson
Nov 11, 2008 11:56 AM
soon2bdropped
Oct 17, 2007 10:10 AM
97dc2
Mar 16, 2007 06:42 AM
Red D Dragon
Jun 11, 2004 08:59 PM
92SiB18C1
Apr 9, 2003 06:40 AM
