idle prob need help 98 b16a swap
Old Aug 26, 2009 | 01:21 PM
spindler1's Avatar
Default idle prob need help 98 b16a swap
hi guys i swaped a a b16a into a 98 integra and its does not seem to idle at all its jumps from 1000rpm to 2000rpm i checked the codes its throwing code 10 IAT sensor i changed it with a new one and check the plug for voltage and there 4.98volts i found out the MAP sensor was bad so i changed that with a new ones and put a new hanress plug on it i check the IAC sensor and its good i checked the harness plug its it good there a jdm p30 chipped ecu inthe car with a stock basemap for a b16a i need help trying to figger out wat is wrong with this car i cant find any more plugs brokin or wires broke all the senors are inthe right place need help thank hope to here from u
Old Aug 27, 2009 | 10:44 AM
spindler1's Avatar
Default Re: idle prob need help 98 b16a swap
bumpp
jayeghatch
Aug 28, 2012 03:59 PM
CGcivicGSR
May 14, 2012 01:47 PM
jceron64
55
Jun 19, 2011 09:41 AM
paratus13
Aug 16, 2004 09:47 AM
b16acrxer
Nov 28, 2003 10:04 PM
