milling an a6 head
i figure that it would probably raise me like a point or so?
Milling heads... I've often thought about doing this, and I did it once, but in hind sight, it's not a good idea. You're taking away material from the head, allowing to to warp easier. Also, if you do it, there's no going back. Just use a thinner gasket. Don't forget that your cam timing will be retarded a few degrees, depending on how much you take out of there.
As for HP gains... well, an engine is an air pump and is only efficient as its biggest restriction. Bump up compression on a stock motor, and you won't see diddly. Do the same to an engine with IHE, and it still probably won't do much. It all works as a system, and if you're going to bump compression, you might as well port (don't polish), get some SS valves, cam grind, ti keepers and retainers, port match everything, extrude hone the intake manifold, bla bla bla... But in the end, everything you do all comes down to one simple equation... $/HP. And lemmie tell ya from experience... NOTHING can beat the $/HP ratio of a turbo. Period.
yes, it probably will raise your compression a point or two (of course, not from, say 11.2 to 12.2, but rather, 11.2 to 11.3, that is what a "point" is). But that also makes your valves that much closer to your pistons, and like F=WT said, will retard your timing slightly.
I would try to avoid milling until you need to.
n2o?
calculate how much $$ your throwing away each time you fill the bottle
n2o?
yes, in time, youll pay for a turbo if you use it that often.
Use that nawwws enough, and it'll pop the motor just ask quick.
n2o is good for cheap-o's like me.
Bottle is fine 'n dandy, but like I said- it's undrivable, and what happens when the bottle runs out? Uh oh! Good thing my boost never needs to be refilled.
yeah, no doubt turbo is better. $557 for turbo!! thats awesome. i want a turbo
candy eg
Jun 28, 2006 01:38 PM
Rhythm Racer
22
Oct 18, 2003 07:18 PM
spettinger
Dec 19, 2002 05:22 PM
