Fuel Pressure
Old Aug 26, 2002 | 11:54 AM
rschoener's Avatar
Default Fuel Pressure
My fuel Pressure drops to 0 after about an hour with the car off not running. Is this normal? I have just installed a Gauge on my Filter and a B&M Fuel Pressure Modifier. Also What Pressure should i be running. I have stock injectors a 4-2-1 Header ,STR fuel rail and intake. Engine is a D16Z6 With P28 ECU. Any help whould be great thanks
Old Aug 26, 2002 | 12:36 PM
raene's Avatar
Default Re: Fuel Pressure (rschoener)
Mine does that too, it's frigging annoying. I think it's the gauge on the filter that's probably loose; I installed a new filter recently + tightened and now it's less prone to doing that.
Old Aug 26, 2002 | 12:49 PM
NikoZai's Avatar
Default Re: Fuel Pressure (raene)
i lose fuel pressure on my b16 too, no regulator or gauge but it makes starting the car a 5-6 crank thing as it needs to suck the fuel in, sounds unhealthy, kinda embarrasing sometimes. So it should maintain fuel pressure at all times?
Old Aug 26, 2002 | 01:05 PM
SOUTHCREX's Avatar
Default Re: Fuel Pressure (NikoZai)
the pressure will aventually drop after time but 30-40 back to 0 in an hour, seems kinda fast. As for you cranking it 5 or 6 times to get it runing, how about you turn the key on "on" and sit their for about 3 seconds while the fuel pump pressurizes everything up, then start the car
Old Aug 26, 2002 | 01:08 PM
Ignitecivic's Avatar
Tthats is normal. it does that cuz the fuel drop when the motor is cold. it will go back up when u crank to ignition or start the engine.
Old Aug 26, 2002 | 01:12 PM
Loco Honkey's Avatar
Stock fuel pressure for a Z6 is 44- 47 PSI at idle. Your bolt ons aren't enough to require more pressure.
BB6racer
Aug 25, 2006 09:19 PM
E46Kid
Oct 21, 2005 10:57 PM
zseeanz
Apr 3, 2004 04:05 PM
TurbodCX
Feb 6, 2002 06:59 AM
