409hp and 306tq on 11.7psi. Decent?
Old Aug 25, 2009 | 05:52 PM
TurboCivic11's Avatar
Default 409hp and 306tq on 11.7psi. Decent?
Setup is 85mm Golden Eagle sleeves
JE 9.0-1
Eagle rods
stock crank
B16 head
Supertech valve spring and retainers
GSR cams
Victor X
Garrett 60-1
SLS topmount
Ebay wastegate
Went to the dyno on a basic Crome street tune just to see and clean up a couple spots. Watchin the datalog it only went to 11.7psi and we came away with 409hp and 306tq pumpgas. Its still very safe on the fuel and timing as the customer beats the living funk outta his car. Its in a 2000 Si. just thought id see what you guys thought. Ill try to get the graph and some pics posted. Customer needs to learn to drive the car on 400hp and then were gonna see what it will do on 25+ and some good gas.
Old Aug 25, 2009 | 05:55 PM
solo227's Avatar
Default Re: 409hp and 306tq on 11.7psi. Decent?
damn thats a some crazy numbers... Big turbo + Big block FTW
Old Aug 25, 2009 | 06:02 PM
Silva Bullit DC4's Avatar
Thats not decent...thats BADASS!
Old Aug 25, 2009 | 06:39 PM
Old Aug 25, 2009 | 06:51 PM
turbo boost's Avatar
nice..what .ar hot side?..stage 3 or 5 wheel?
what rpm did it reach 11.7psi buy?
Old Aug 25, 2009 | 07:11 PM
Not too sure of the turbo. It was at full boost by 5500.
Old Aug 25, 2009 | 07:18 PM
miller's Avatar
are you on the stock map sensor?
Old Aug 25, 2009 | 07:25 PM
hondapowerb16a2's Avatar
its a garrett t3/t4 60 trim with .63ar turbine and a .60ar compressor it has a 76 trim stage 3 wheel
Old Aug 25, 2009 | 07:49 PM
narfdanarf's Avatar
lol, that's what I was thinking
Old Aug 25, 2009 | 08:03 PM
jdm602's Avatar
dang full boost (11.7 psi) at 5500?
...or do you mean wastegate opens at 5500?
Old Aug 25, 2009 | 08:30 PM
No its on a GM 3bar map....but the owner has to learn to drive with that much power. Thats why were sittin at 12psi for now. let him get some seat time with this power and then more boost will come.
And no...its at a full 12psi by 5500, pretty much right when VTEC comes in.
Thanks Rick.....yours is next!
Old Aug 25, 2009 | 09:07 PM
jdm602's Avatar
coo, yea deff nice numbers!
Old Aug 25, 2009 | 09:11 PM
t66crx's Avatar
good numbers on that low of boost. when you say pump gas is that 91,93 or E85
Old Aug 25, 2009 | 09:20 PM
jasoncrashtech's Avatar
sick numbers
Old Aug 25, 2009 | 09:27 PM
d112crzy's Avatar
What shop is that?
Those are some good numbers. Post the graph.
Old Aug 26, 2009 | 12:32 AM
Its my business here in Spokane. 1320 Hondas.
And its on 92 octane Shell gas.
The dyno was a DynoCom dyno.
Old Aug 26, 2009 | 12:37 AM
spoolin94ls's Avatar
nice
Old Aug 26, 2009 | 04:04 AM
d16z6Tcrx's Avatar
thats alot of power for a 60 trim at 12 psi....
Old Aug 26, 2009 | 05:00 AM
boosted k20's Avatar
thats a lot of tq! i would like to see that on a dynojet
Old Aug 26, 2009 | 05:12 AM
blaze the chemi's Avatar
beautiful numbers out of a 1979 cc motor at that boost level. I'm jealous especially since I have a 2000 Si too.
I'm interested in more of the setup such as DP and exhaust. Is the B16 head stock or is he using different cams?
Badass indeed.
edit: I can't read...GSR CAMS...DUH!
Old Aug 26, 2009 | 06:06 AM
cant wait!
Old Aug 26, 2009 | 06:08 AM
Badass indeed.
head is slightly ported supertech valvetrain and gsr cams 3" open downpipe
Old Aug 26, 2009 | 07:39 AM
ERIC1's Avatar
U know those are great numbers u wer just tryn to brag!!! lol
Old Aug 26, 2009 | 07:56 AM
d112crzy's Avatar
Those are definitely great numbers, especially that torque. I've never seen the torque numbers be so close to the hp number on a B series. Are you guys using std length rods?
