ITR LCAs and Strut ?
Old Aug 25, 2009 | 05:49 PM
jdmcrx_echelon's Avatar
Default ITR LCAs and Strut ?
Well im pretty positive on this but i want to make 100% sure before i order suspension. I drive A Civic SiR which comes with the similar suspension setup as an ITR.( Rear strut and lower control arm are different from any other civic/integra) Im Ordering a full coilover and LCA setup and im wanting to use the typical civic setup. So if i order the regular setup it should bolt right up correct? or would i HAVE to order an ITR setup?
Old Aug 25, 2009 | 06:11 PM
Gunmetal_B20_Hatch's Avatar
Default Re: ITR LCAs and Strut ?
pretty sure that you are going to need ITR style shock bodies with the bushing in the shock body, not in the LCA.
Old Aug 25, 2009 | 06:43 PM
ej1serge's Avatar
i have a set of itr lca's if u need em, unless u have some already, ill sell em for cheap too
Old Aug 25, 2009 | 08:57 PM
thumper64's Avatar
It would bolt up. You already answered it yourself. The shock and LCA are different, but you're ordering the normal setup to replace the two different parts.
Old Aug 25, 2009 | 09:00 PM
Thanks thumper... I just wanted to make 100% sure that it would work if i went that way.
egsleepercivic's Avatar
yeah if you order the non type r style lca and coilovers they will work or the type r coilovers would work with your current lca, just match them up
Cesar_CPR
Jan 23, 2007 05:45 AM
mrdeadman
Mar 20, 2006 03:56 PM
racekar
Jul 25, 2004 06:50 PM
Hunter
14
Jan 17, 2003 01:25 PM
Civic44
Jul 8, 2002 04:04 PM
