ITR???
Re: ITR??? (JDMFLAVOR)
depends what you mean by suspension?
if you mean just the shocks/springs then yes. all you need is the rear itr lca and it will bolt on. fronts will bolt in just fine.
if you mean the itr 5 lug, then you would need to get the usdm itr 5 lug since you're going to be using the 32 mm for the fronts so yes, it will work. you have to get the whole rear assembly for it to work with your arms as well.
serious
12-11-2002 08:33 AM
