Idling woes 99-00 em1
Old Aug 25, 2009 | 01:28 PM
taimysho0's Avatar
Default Idling woes 99-00 em1
hello, searched forums and still no avail
problem: sometimes car starts at 2000 rpms on cold start, need to restart car to make it go back to normal. sometimes ill be driving, at a stoplight or when car is in neurtal rpm is about 1100. need to restart car to solve.
attempts: already tried cleaning IACV screen, it LOOKS clean, no dirt blockage. checked for vacuum leaks found none, tightened all bolts and clamps on air filter. cleaned MAP sensor with map sensor cleaner.
any other suggestions to help me withis prob? thanks
Old Aug 25, 2009 | 01:39 PM
Former User's Avatar
Default Re: Idling woes 99-00 em1
Is the CEL on?
When the idle is high, pull off the intake and use you finger to cover the port in the throttle body leading to the IACV. If the idle speed drops, try adjusting the idle speed:
Old Aug 25, 2009 | 02:03 PM
98civdx's Avatar
Master Detailer
i second above
Old Aug 25, 2009 | 02:09 PM
taimysho0's Avatar
what is the cel? can you tell me how to turn it off??
Old Aug 25, 2009 | 02:20 PM
Originally Posted by taimysho0
what is the cel?
Click here. Pull the CEL codes and post them.
Old Aug 25, 2009 | 02:27 PM
taimysho0's Avatar
ok for the idling screw, do i leave the car on when turning the screw or is the car off? also do i turn it left or right to lower idle? thanks
Old Aug 25, 2009 | 02:31 PM
taimysho0's Avatar
check engine light is NOT on
Old Aug 25, 2009 | 05:00 PM
taimysho0's Avatar
hello, can sum1 please lmk which way to turn the screw and if its with car on or off? thanks!!
99ek4Dr
10
Mar 2, 2011 06:22 PM
fav6052
Aug 15, 2008 07:49 AM
xd69
Apr 13, 2008 01:35 AM
ibe2fly
31
Nov 21, 2005 04:17 PM
LSBeast
Jun 13, 2003 09:06 AM
