Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shim clearance ??
Old Aug 25, 2009 | 01:13 PM
dutchman5's Avatar
Default Shim clearance ??
I just installed obx lsd in b16a hydro tranny but I have a problem understanding with shim clearance!
I have honda manual and it saying clearance should be .000-.004. I measure my old shim 1.35 and it showing .000 clearance but I m not sure if that was too tight cause I try use .001 to .003 feeler gauge. But it wont go through between lsd and shim.
I just want ask if is it safe to use or order other shim?
thanks
Old Aug 25, 2009 | 01:58 PM
Aquafina's Avatar
Default Re: Shim clearance ??
If the gauge won't go in then that is not the clearance. So if you can't get a .001 in, then the clearance is at most .0099. As long as it spins with zero clearance it is ok, but there are better clearances to use based on the type of driving you'll be doing.
Old Aug 25, 2009 | 04:42 PM
dutchman5's Avatar
Do u think the clearance I have right now should be okay for daily drive?
I want to make sure before I put tranny back.
thanks
Old Aug 25, 2009 | 04:56 PM
b20beast83's Avatar
get the correct clerance
Old Aug 25, 2009 | 05:11 PM
Aquafina's Avatar
Its fine for daily driving.
Old Aug 25, 2009 | 07:09 PM
dutchman5's Avatar
Ok thanks !
Old Aug 26, 2009 | 01:49 PM
Mista Bone's Avatar
D Tranny Guru
I should have a few spare 1.30mm shims if you wanna try one.
smoovy
Feb 4, 2009 05:34 PM
lakai_19
Oct 22, 2007 06:10 PM
CivicSwapper
Nov 30, 2006 02:16 PM
j87w
Jan 12, 2005 12:36 AM
Taco Sauce
Oct 15, 2002 09:31 AM
