96 GSR Top End Motor Ticking
Old Aug 25, 2009 | 12:31 PM
RacerTim's Avatar
Default 96 GSR Top End Motor Ticking
I thought I had something loose on the exhaust system, but it turns out it is coming from the top end of the motor. It only occurs from 3300 to 3600 RPM.
Motor is all original and has 133k. Any ideas what it could be or what I could test?
Thanks!
Old Aug 25, 2009 | 02:25 PM
8zero8's Avatar
Default Re: 96 GSR Top End Motor Ticking
valve lash
Old Aug 25, 2009 | 02:30 PM
boarding2008's Avatar
Same problem here. It happens around 3100-3300for me. It sounds like a heat shield is loose. But got under there while someone reved it. Pushed pulled on the shields but nothing. Then listened and it sounds like the head. So how do I fix this if its valve lash. Is it dangerous? Will my motor blow?
Old Aug 25, 2009 | 02:58 PM
8zero8's Avatar
adjust the valve clearance.
Old Aug 28, 2009 | 04:35 AM
RacerTim's Avatar
http://www.team-integra.net/sections...?ArticleID=485
How-to for those interested.
Old Aug 28, 2009 | 11:01 AM
illicit_kustomz's Avatar
or http://www.c-speedracing.com/howto/v...alveadjust.php
Old Aug 28, 2009 | 01:15 PM
HeikDiesel's Avatar
also worn lost motion assemblies will do this, but more than likely loose valve lash
Old Aug 28, 2009 | 03:56 PM
8zero8's Avatar
^^ right.. i must have adjusated my valve lash like 10 times before i finally changed out the lost motions... it would be cherry for a few days then start ticking... but no sense buy those if all you need to do is adjust the clearance.
Old Aug 30, 2009 | 02:42 AM
type_RsLick's Avatar
you may need some valve adjustments...or you may have the same problem i encountered, i had slight "ticks" from idle to mid 4500rpm's. at the time i really didn't have any time to get it fully checked out so, i used a little thicker oil and it solved the prob...well, goodluck on yours. it's really hard to tell if i can't see or hear the problem you're having...
HondaKid_1
Jul 28, 2008 10:47 PM
h46it
Sep 20, 2006 09:10 AM
slownlow90
Mar 9, 2005 09:04 PM
raser5050
Oct 20, 2003 12:29 PM
LBDM EK97
Oct 16, 2003 09:09 PM
