Gauge Cluster, Turn Signals, Clock wont work.
Old Aug 25, 2009 | 09:10 AM
jOnW89's Avatar
Default Gauge Cluster, Turn Signals, Clock wont work.
My tails lights and headlights work and hazards but nothing else. No speedo/rpms/temp gauge/gas gauge/clock/turn signals. The cluster still lights up also.
I checked to see if anything was unplugged behind the cluster all is plugged in. I also checked my fuses and all are good... Any ideas?
Old Aug 25, 2009 | 09:17 AM
Former User's Avatar
Default Re: Gauge Cluster, Turn Signals, Clock wont work.
It's most likely a blown fuse under the dash. What year?
Old Aug 25, 2009 | 09:26 AM
jOnW89's Avatar
It's a 93 civic hatch I checked all my fuses as stated in first post.
Old Aug 25, 2009 | 09:49 AM
Recheck 10A fuse #15 under the dash. Just replace with a new 10A fuse.
Old Aug 25, 2009 | 10:02 AM
jOnW89's Avatar
I tried that also...
Old Aug 25, 2009 | 10:08 AM
VEGAN_EG's Avatar
grab a wiring diagram and check the ground for those?
Old Aug 25, 2009 | 12:54 PM
Is there battery voltage at fuse 15 with the key in ON(II)?
The diagram below shows all components protected by 10A fuse #15 under the dash. Do any of these components work? If so, which ones do work?
Old Aug 25, 2009 | 09:46 PM
jOnW89's Avatar
My hazards work. Nothing else but cluster does light up.
Old Aug 25, 2009 | 09:57 PM
The hazard lights are actually protected by a different fuse under the hood. Check for battery voltage at fuse #15 with the key in ON(II).
Old Aug 26, 2009 | 08:04 AM
jOnW89's Avatar
I believe so if fuse 15 was not getting power the cluster wouldn't light up would it?
Another thing I noticed even with my key all the way forward my car makes the beeping noise when the door is open and only use to when the key was not all the way forward.
Old Aug 26, 2009 | 08:45 AM
The gauge lights are on a different circuit. They are instead protected by fuse 19. Check for battery voltage at fuse #15 with the key in ON(II).
Old Aug 29, 2009 | 06:36 PM
jOnW89's Avatar
yea im getting power to that fuse. im still stumped!
Old Aug 29, 2009 | 06:44 PM
When you put the car in reverse, do the backup lights work?
Old Aug 29, 2009 | 06:51 PM
jOnW89's Avatar
they would if I had the sensor in my tranny.
Old Aug 29, 2009 | 07:10 PM
Do you know how to remove your cluster? Does the cluster have a tach?
Old Aug 29, 2009 | 09:03 PM
jOnW89's Avatar
yea I already took it out yes it has a tach nothing works all the clips are in
Old Aug 30, 2009 | 06:35 AM
Remove the cluster, unplug the connectors, and test for voltage at terminal A3 of connector A with the key in ON(II).
Old Aug 30, 2009 | 05:03 PM
jOnW89's Avatar
Will do in a few will keep you posted.
Old Aug 31, 2009 | 01:26 PM
jOnW89's Avatar
Nothing on the clip got power when I tested on the A clip. On clip B with key forward I got power at b3 and with lights forward power at B2. Should I splice b3 and a3 together?
Old Aug 31, 2009 | 01:56 PM
Does a Yel wire pin to A3?
Old Aug 31, 2009 | 02:02 PM
B3 should be the right turn signal indicator light and B3 should be the speed signal from the VSS. Give me some wire colors at the pins.
Old Aug 31, 2009 | 02:05 PM
Are you mixing up the A and B connectors?
Old Aug 31, 2009 | 02:37 PM
jOnW89's Avatar
Nope I know for sure I am not the A Connector only has 10 pin outs when the B has 12.
Old Aug 31, 2009 | 02:46 PM
What about wire colors at the pins you are talking about?
Old Aug 31, 2009 | 03:56 PM
jOnW89's Avatar
A3 is a solid yellow wire with silver spots in some places no power goes to this wire.
