would oil in the combustion chamber show on the plugs??
Old Aug 25, 2009 | 05:34 AM
robbys89's Avatar
Default would oil in the combustion chamber show on the plugs??
ok my friends car eats through oil like a **** but when the sparks are removed thier clean, i know running rich turns them black, blue smoke indecates burning oil but his smoke is more black so anything else too look out for? no leaks around the engine by the way!
Old Aug 25, 2009 | 05:38 AM
Paul-R's Avatar
Default Re: would oil in the combustion chamber show on the plugs??
pull your plugs and find out ....
Old Aug 25, 2009 | 07:09 AM
vtechjunkie's Avatar
Engines eat oil for many reasons. But just because the oil is black does not mean it only rich. I've had a motor put out black smoke before, and it was oil and a little rich. Not really rich. Check the compression on the motor and do a leak-down test to see what the rings and head are doing. That might tell you more.
vicarnes
Jul 5, 2005 03:11 PM
Blazin Si
19
Jun 26, 2005 08:59 AM
peel17
Feb 1, 2005 11:28 AM
carcala
May 17, 2004 06:19 PM
citanest
Oct 18, 2001 09:27 PM
