What Flywheel with a ZC
Thanx Home Skillet... I bought an AutoMatic tranny equipped ZC from the engine joint. so I got that flexplate and Torque Converter in there.... I didnt wanna pay the engine guys another $100 (flywheel) for a part I already have. Thanx!!
I guess I'll reuse my water pump, plugs, wires, flywheel, clutch, axles...
Well then I dunno what the heck it is then, I had both the Si and this flywheel next to it, and this thing is half as thick. It weighs 11 lbs.
It was on my ZC when I got it.
Here:
If anyone wants it let me know... It has to be an OEM piece because it looks so OEM to me.
Here:
You might want to have your flywheel resurfaced while its apart to prevent your clutch from slipping in the future. This is something I wish I did while I had it apart.
What size 12point socket do we use to remove the flywheel it looked like a 15mm 12point?? I ask cause I gotta go buy one.. I just have one 12point socket for the clutch and the rest of my tools are 6point
what tranny are you using on your ZC, if you are using the ZC tranny, i believe you need a 86-89 integra, if you are using you stock si tranny or whatever im sure the stock flywheel will work
Im using as many stock Si parts as I can. I recently did a complete overhaul on my poor Si. so i got a brand new centerforce stage3 and new axles and all new tuneup parts plugs wires diz cap&rotor. The timing belt slipped and I am just not ripping out that engine again... I will just "have" to swap :D So I'll be using my Si flywheel clutch and Tranny.
i hate rice
Jun 23, 2006 10:47 AM
