What Flywheel with a ZC
Old 08-26-2002, 10:36 AM
BigDaddyRich's Avatar
Default What Flywheel with a ZC
Can I use my existing Civic Si flywheel with this motor? if not which one...
Old 08-26-2002, 10:46 AM
Home Skillet's Avatar
Default Re: What Flywheel with a ZC (BigDaddyRich)
yes you can.
Old 08-26-2002, 11:02 AM
Default Re: What Flywheel with a ZC (Home Skillet)
Thanx Home Skillet... I bought an AutoMatic tranny equipped ZC from the engine joint. so I got that flexplate and Torque Converter in there.... I didnt wanna pay the engine guys another $100 (flywheel) for a part I already have. Thanx!!
I guess I'll reuse my water pump, plugs, wires, flywheel, clutch, axles...
Old 08-26-2002, 01:15 PM
dustin's Avatar
I have an OEM ZC flywheel if you want it. It's factory lightened.. 11lbs..
Let me know.
Old 08-26-2002, 01:22 PM
zcivic91's Avatar
Default Re: What Flywheel with a ZC (dustin)
factory lightened?? BS!!! they weigh as much as the si's
Old 08-26-2002, 01:24 PM
dustin's Avatar
Default Re: What Flywheel with a ZC (zcivic91)
Well then I dunno what the heck it is then, I had both the Si and this flywheel next to it, and this thing is half as thick. It weighs 11 lbs.
It was on my ZC when I got it.
Here:
If anyone wants it let me know... It has to be an OEM piece because it looks so OEM to me.
Old 08-26-2002, 04:09 PM
oldskool_rex's Avatar
looks OEM, but was prolly shaved down by previous owner
Old 08-26-2002, 04:15 PM
Hondasaurs's Avatar
You might want to have your flywheel resurfaced while its apart to prevent your clutch from slipping in the future. This is something I wish I did while I had it apart.
Old 08-26-2002, 04:24 PM
dustin's Avatar
Default Re: What Flywheel with a ZC (oldskool_rex)
The back side is cast, not shaved.
Old 08-26-2002, 04:37 PM
What size 12point socket do we use to remove the flywheel it looked like a 15mm 12point?? I ask cause I gotta go buy one.. I just have one 12point socket for the clutch and the rest of my tools are 6point
Old 08-26-2002, 04:47 PM
wronghand's Avatar
17mm for the flywheel, 12mm for the pressure plate.
Old 08-26-2002, 05:06 PM
FBPninetynineEM1's Avatar
Default Re: What Flywheel with a ZC (wronghand)
what tranny are you using on your ZC, if you are using the ZC tranny, i believe you need a 86-89 integra, if you are using you stock si tranny or whatever im sure the stock flywheel will work
Old 08-26-2002, 05:30 PM
Default Re: What Flywheel with a ZC (TDRef9)
Im using as many stock Si parts as I can. I recently did a complete overhaul on my poor Si. so i got a brand new centerforce stage3 and new axles and all new tuneup parts plugs wires diz cap&rotor. The timing belt slipped and I am just not ripping out that engine again... I will just "have" to swap :D So I'll be using my Si flywheel clutch and Tranny.
JohnW8
04-11-2011 06:58 AM
nightlife88
Classic Hondas
01-11-2008 04:29 PM
i hate rice
06-23-2006 10:47 AM
cr-x si
10-16-2002 03:20 PM
Quick Reply: What Flywheel with a ZC
