93 del sel with b18c ITR troubleshooting
Old Aug 24, 2009 | 09:00 PM
minimeboost's Avatar
Default 93 del sel with b18c ITR troubleshooting
ok so my friend has the 93 del sel with a b18c ITR and one day it just stopped sparking and we cant figure out why it wont spark.
the computer is fine
the distributor is good
the coil is good
what else can make this spark. please any info would help.
thanks sincerly
lucas
Old Aug 24, 2009 | 09:07 PM
Former User's Avatar
Default Re: 93 del sel with b18c ITR troubleshooting
Is the CEL on? Does the fuel pump prime?
slowhatchcali's Avatar
how do you know the dizzy is good? have you swapped it for a known working one?
Old Aug 24, 2009 | 09:13 PM
the fuel pump primes and we bought a used one and the kid said it worked but we dont have the 500 bucks for a new one and we cant find anyone in utah with this motor and thereis no check engine light
Old Aug 24, 2009 | 09:14 PM
a used dizzy btw sorry
Old Aug 24, 2009 | 09:16 PM
sorry he just told me it throws a secondary o2 sensor code and a knock sensor but only cuz it has the eg wiring harness so there is no wires and it was running with those codes
Old Aug 24, 2009 | 09:17 PM
damn... thats weird.. are you spark plug wires good? all your grounds on good?
Old Aug 24, 2009 | 09:18 PM
yyes they are thats one thing we checked first
Old Aug 24, 2009 | 09:27 PM
Has the igniter unit in the distributor been tested?
With the key in ON(II), do you measure battery voltage on the Blk/Yel wire attached to the coil and igniter unit in the distributor? What voltage do you measure on the Yel/Grn wire attached to the igniter unit?
Did the timing belt snap?
Old Aug 24, 2009 | 09:33 PM
i will have him check that and get back with you and no it has not the motor has only 50k on it
Antibullllseye
Jul 23, 2016 02:56 PM
86aw11
Dec 28, 2015 03:37 AM
Hookeduphatch
Apr 24, 2009 05:37 PM
d_a_b
Oct 11, 2006 09:14 PM
