93 del sol help
Old Dec 24, 2015 | 01:37 PM
86aw11's Avatar
Default 93 del sol help
I really need help with this 93 del sol. Brand new pump filter main relay O2 sensor starter distributor rotor and cap plugs wires. Pump is not getting any fire. Hooked the pump up to a hot fuse and it turned on. The pump is good I just can't figure why it's not getting power
Old Dec 28, 2015 | 03:37 AM
ej8's Avatar
ej8
Default Re: 93 del sol help
Check the signal coming from the ecu if all else is good in the in-vehicle system. If the ecu does not send out the signal, it will not work.
If you find this to be the problem, PM me and I can help you to get it working again.
DarkGriffin3156
11
Nov 21, 2021 05:33 PM
whiteheadk62
15
Jul 23, 2014 05:19 AM
delsolmommy
12
Apr 3, 2012 10:08 AM
amfer03
May 9, 2009 09:32 PM
almostjdmeg
Jul 21, 2008 05:19 AM
