Chipped P06 shorting out...
Old Aug 24, 2009 | 03:17 PM
AltimaXX's Avatar
Default Chipped P06 shorting out...
I attached a few shitty cell phone pics...short recap is that the ECU fritzed out when I tried to start the car the other night...Any ideas what might have caused this?
Symptoms included the tach needle jumping, the car filling with smoke, and the cooling fans staying on all the time. The main relay stopped clicking when the car was turned to 'on' and the fuel pump isn't coming on.
In the pic of the
"top" of the circuit board, the burn is right under the silver canlike object...capacitor maybe?
Old Aug 24, 2009 | 03:23 PM
93turbo16's Avatar
Default Re: Chipped P06 shorting out...
In the pic of the
The main capacitor took a dump.
That one looks pretty bad and probably won't be easy to fix. I would suggest just picking up another chipped ecu. And make sure it comes with a new capacitor!
Old Aug 24, 2009 | 03:53 PM
AltimaXX's Avatar
I was assuming so...I suppose I'll be ordering a second one from you then. Can you tell me two things? Would this take the main relay and/or anything else external to the ECU with it? Also...would this capacitor being gone cause the main relay not to click?
:edit:
Would the chip with the basemap still be good?
Old Aug 24, 2009 | 05:10 PM
mtber's Avatar
The chip & basemap should still be good in the ecu.
The primary cap simply failed. I would recommend re-checking your wiring if you have modified it recently. (Caps sometimes fail due to old age & use).
Old Aug 27, 2009 | 03:20 PM
Ag-Eng's Avatar
It can be fixed. PM me if you're interested in getting it repaired.
Evos
Engine Management and Tuning
12
Nov 12, 2019 10:57 AM
651DelSol
Aug 21, 2013 09:51 AM
AltimaXX
Aug 24, 2009 03:42 PM
sup22
Nov 3, 2007 01:22 PM
turbocivic96
Mar 15, 2004 12:44 PM
