How do you replace power steering belt 94 accord?
Old Aug 24, 2009 | 02:11 PM
Greatness's Avatar
Default How do you replace power steering belt 94 accord?
How do you replace a power steering belt in a 94 accord LX 4 dr. F22B2
Old Aug 24, 2009 | 05:26 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: How do you replace power steering belt 94 accord?
Loosen the bolts holding the pump in place - should be 3
Remove belt
Put new belt and tighten bolts
Old Aug 25, 2009 | 11:03 AM
BBallz24's Avatar
Remember when you used to ride bikes and the chain would come off? Same concept here. Put belt around one pulley, and then start it around the bigger pulley. Crank engine over for a second and belt should go on no problems.
Old Aug 26, 2009 | 07:55 AM
Greatness's Avatar
Thanks
Old Aug 26, 2009 | 09:39 AM
bopbop93030's Avatar
There is one bolt in the PS that is for adjustment for tightness.
Old Aug 26, 2009 | 09:47 AM
kccord's Avatar
As said loosen the pivot bolt and the tensioner bolt, should be around 3 bolts. Push it to the most slackest setting, take off old belt, put new one on. DO NOT CRANK THE MOTOR TO PUT THE BELT ON IT SHOULD JUST FIT ON THE SLACKEST SETTING.
Check tension by pressing the belt between the two pulleys, it shouldn't deflect more than half an inch.
jarred1414
Nov 14, 2014 10:27 AM
Ajax_Integra
Jun 10, 2013 03:46 PM
jcinwelland
Mar 4, 2009 09:42 PM
J9D6M
Jul 13, 2006 06:28 AM
Scharged00GsR
Jul 12, 2004 05:58 AM
